Computers & Internet Logo
W
Williams bobby Posted on Dec 03, 2017
Cannot see my Kodi settings legacy when I turn it on can t get to it
Only see my settings when I delete I want to be able to go to it anytime
1helpful
Black and White Movies Kodi Add on?
How To Install Black and White Movies Kodi Addon
WirelesSHack https://www.wirelesshack.org > how-to-install-black-a...
Jan 15, 2024 - How To Install Black and White Movies Kodi Addon · At the top left click the System Settings (Gear Icon) · Click File Manager · On the left click ...
How to Install Black and White Movies Kodi Addon
Fire Stick Tricks https://www.firesticktricks.com > black-and-white-mo...
Dec 1, 2023 - How to Install Black and White Movies Kodi Addon · 1. Select the Cog icon under Kodi's logo on your Kodi app home page. · 2. Launch the File ...
‎What is Black and White... · ‎How to Install Black and White... · ‎FAQ's
Black And White Movies Kodi Addon (Movies)
Kodi-Guide.com https://www.kodi-guide.com > black-and-white-movie...
Dec 10, 2023 - Install Black And White Movies Kodi Addon · In your addon browser select "Install from repository" · Select the installed "Diggz Repository" · Open ...
Black and White Movies Kodi Addon - Installation Guide for ...
TechyMice https://www.techymice.com > kodi > how-to-install-bl...
Installing Black and White Movies Addon on Kodi is simple. Follow the instructions below to install the addon on your Kodi-compatible devices like Windows, Mac, ...
I can't get sound on my kodi. What am I doing wrong?
Reinstall Kodi
But make sure that you uninstall Kodi first and then reinstall it again if the sound issue has been resolved.
Update Kodi with the latest version
A new release of Kodi version can fix some bugs and gives a better experience. To install the latest Kodi go to the download page/application store and update Kodi.
Reconfigure the Audio Settings on the Kodi
Sometimes incorrect audio settings in Kodi can cause the no sound issue, you need to check the audio settings by the following procedure.
  • First, launch Kodi on your device.
  • And on the home screen of Kodi click the Settings button.
  • After that, Click on the System Settings.
  • And now Click on the Standard to change it to different settings mode until and unless you don't see Advanced in the left pane, once you get it, click Advanced to go to the Advanced settings.
  • Then Click Audio in the left pane, and adjust the audio settings to match your audio output device.
  • After that, restart the device and try it again to see if the sound is working or not.
Check hardware issue
Sometimes hardware issue causes no sound issue in your computer so check your hardware works or not by following the steps.
Check Audio Cable
Always see that audio cable works or not while using Kodi TV box or speakers, you can try another audio cable and try your audio cable in another device to troubleshoot.
Check Connecting Ports
Check on the connecting ports and ensure that the connecting ports are working nicely sometimes dust in ports causes the issues so use the brush to clean the brush and try it again.
Check Bluetooth Audio Connection
And if you are using the Bluetooth audio connection always pay attention to the unstable Bluetooth connection because Bluetooth connection will be interfered by other signals so be careful and turn off other Bluetooth connection and try to turn off the Bluetooth connection on Kodi, and turn it on to see if it works or not.
Update the sound driver on Windows
In the window to fix the sound issue on Kodi, you can upgrade the sound driver and, by going to the manufacturer's website, you can manually update your audio driver then download latest sound driver for your Windows computer.
  • If you don't have enough time and you don't want to wait to then do it automatically with Driver Easy.
  • Download and install Drive Easy
  • Now run the Driver Easy and click the Scan Now button it will scan and detect any problem drivers.
  • Now click on the Update All the automatically download and install the correct version.
Restart your computer to make it take effect
After updating the sound driver again try Kodi to see if the sound's working.
Run Kodi in another device
If above mention doesn't solve the issue then, try Kodi in another different device. Something must be wrong with the hardware device.
2answers
I installed kodi krypton. Now i cant get out of that settings page and back to my regular screen..
Update your Kodi app and install a good Kodi build. Here are the updated and working best kodi builds you can install. 8 Best Kodi Builds for Best Kodi Setup The Tech Toys
1helpful
2answers
After installing kodi 16.1 jarvis ..getting message kodi has stopped working !!!
There is a possibility that you have your cache filled up on kodi. You can clear cache on kodi by following the given steps at the end of this post. Secondly you can setup best kodi builds to continue smooth streaming.
Clear Cache on Kodi:
  1. Open Kodi Jarvis > Then click on System menu in front of your screen > Now select File Manager > Double click Add Source option at the bottom.
  2. Once you click on Add Source, a box will soon appear where you need to click on 'None' option and type http://srp.nu/ > Click Done > Type URL Name below 'Super Repo' > Click Done > Then click OK.
  3. Once you are done, go back to Kodi Main Menu by pressing 'Esc' button on your keyboard > Go to System > Then select Add-ons > Then click on Install from Zip File > Super Repo > Then select Jarvis > Click on Repositories > Superrepo > superrepo.repo.0704.zip
  4. Now select Install from Repository > Then Super Repo Repository [Jarvis][v6] > Go to Add-on Repository > Select SuperRepo All Repository [Jarvis][v6] > Hit Install
  5. Go back two steps and click on Install from Repository > SuperRepo All Repository [Jarvis][v6]> Program Add-ons > Merlin Wizard > Install
  6. Open Merlin Wizard, go to Tool Box option > Here you will presented with 3 options i.e. Clear Caches, Delete Packages, and Delete Thumbnails. The space that each of these options consume are also listed below these options.
19 Best Kodi Builds To Experience The Colors Of Kodi
I have a android box and want to download kodi on my laptop and put a build on it can i transfer it on a memory card and set it up on the android box
Transferring a build over on a memory card then putting on an android box is technically possible but it would be very hard in making sure you get all the files correctly over and installed in the right paths.
The easiest way for you to install a build is to first install Kodi Kyrpton on your Android Box then once Kodi is installed, from within kodi install your build.
Feel free to check the link I posted, its a blog post on how to install kodi builds. Theres full screenshots and youtube videos to help with learning how to do installs. Once you do it a couple times you will be able to do it hands down anytime. Anyways I hope this helped you and good luck with installing your new build.
Best Kodi Build List for 2018 Must Read Before Installing BestBox
Ms8 ott box by kodi video stops goes to home page almost like screen saver but setting for screen saver is never
check the kodi settings. Kodi is just an app that runs on your android TV box so youll be dealing with 2 types of settings....setting within the box and the settings within kodi. I am thinking one of those sets of settings has the screensaver checked on
Top Legacy Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Legacy Computer and Internet Expert? Answer questions, earn points and help others
