The two support poles from plastic base to main pole have been rusted and broke, need to replace to keep using the hoop system.
SOURCE: I desparately need some assembly instructions for my Barbie tent.
Mattel products, including Hot Wheels, Barbie and Polly Pocket:
In the US and Canada: 800-524-8697
SOURCE: Need replacement poles for Cabin Tent
Do you have a Northwest outlet in your area? Otherwise you can get it from the manufacture.
SOURCE: We just purchased a used '99 Starcraft Field &
I had exact same problem on my 93 popup. I finally figured it out. First, the poles with the plastic rings slide into the poles with the metal rings. These are the vertical support poles. Next, the poles w/ plastic nipples slide into the other poles with rubber ends. When put together the poles with the nipples should be spring loaded. These spring loaded poles rest against the top of the camper and the nipples are inserted into the 3 holes of the pole that go across the front of the awning giving you rafter support. The tension from the spring should keep the pole in place against the side of the camper. The first 3 poles with the plastic rings go from the ground to the front awning pole where the nipples can slide through the plastic ring and then into the awning pole. The vertical poles can be adjusted for height by sliding them up or down and then twisting them like a screw to tighten them up and keep them in place. 2 of my 3 vertical poles will not lock when I twist them so I have to get tricky with them. The metal rings, which should now be at the ground, are there so that you can stake it down under windy conditions. I hope this wasn't too confusing but I beleive it will help you. Good luck!!!
SOURCE: Where can I get replacement flag poles yard cargo hoist yard arm?
They can be ordered by part number from the Playmobil Company, http://playmobil.com . If you don't have your instruction sheet, look up the part numbers here:
http://playmodb.org/cgi-bin/showinv.pl?setnum=3286&pics=on
and give the numbers to Playmobil customer service.
SOURCE: The plastic female part of my Remington
Okay here is the Fix for the Remington Pole for the remington saw. Lowes has a plumbing part that will work as I just purchased it 12/2010 The part is by GENOA and its a 3/4" pvc Union and the threads match. Its Lowes part 98996 and its < $6.00
A pole weapon or pole-arm is a close combat weapon in which the main fighting part of the weapon is placed on the end of a long shaft thereby extending the user's effective range. The pole arm is commonly used in Chinese martial arts.
A pole-arm is a
the end of a long shaft, thereby extending the user's effective range. Glaives,
poleaxes, halberds, and bardiches are all varieties of pole-arms.
