The SD card is formatted to FAT 32 and the music is all MP4 files....HELP
Most likely file format is incorrect for that speaker. Most of the speakers plays mp3 files as music where mp4 are commonly video files.
Whats the speaker model ? are you talking about this one https://zebronics.com/products/5-1-floor-standing-speakers/shark-bt-rucf. According to me this one supports SD card and also accepts MP3 file format. Probably check whether your card is damaged or you have any issues in the sd slot.
SOURCE: unknown format
I have 1GB fast speed Goodram sd card and its ok, but i thing more is not possible because of memmory adressing limit.
SOURCE: I load regions to sd card and meridium platium does not recognize
You do not need to screw with an SD card, they are formated to take whatever data you send to them, but in your case check by reading the card to see what is on it BEFORE you put it in the GPS. It may have junk files on it, thus there is no room, unless of course you try to load to much data, THERE IS A LIMIT, suggest you read the GPS manual, and see what the limit of the size of the card is for that GPS, yes there is a limit!
SOURCE: Cant format micro SD Card
try to reformat the sd card to the required FAT 16.... use a computer..and sd card adoptor for you to connect the card to the computer
tnx
SOURCE: using wmp to sync to mini sd card for a moto ve240 mp3 player
the device has to format the card. at this time the phone will create folders for music, videos, images, and what not. now when you insert the card into your computer you will open the card and copy the files to the music folder. this will allow access to the files from the handset visual platform.
Good Luck and please rate this solution!! :D
SOURCE: Can't format sandisk micro sd card in my moto rokr
dear sir,
if you have laptop and if it has sd card slot then put the card in the slot
go to my computer
right click on removeable drive
and selet format
selet the "FAT" option on top of the window
click ok
now your card is formatted and you can use it
if you don't have sd card slot then you have to buy or borrow from friend card reader and do it from there.
hope it will solve your problem sir
