https://www.lacrossetechnology.com/products/.../misc/8117-manual.pdf
NOTE: Do not set the clock until the outdoor temperature is displayed. .... The unit will still try and receive the signal every day despite it being manually set. ..... sunlight, extreme cold and wet/moist conditions as these will lead to rapid changes ... Beforesending the atomic clock in for repairs, contact La Crosse Technology.
https://www.lacrossetechnology.com/support/top_solutions.php
A: Complete a restart for display with the temperature/humidity sensor: ... to rest for 15 minutes can result in failure to connect with the outdoor sensor or missing ... Products set outside of these time zones will not search for a WWVB signal as it is ... locate the Clock or Weather Display near an outside wall and point the unit in ...
www.weather-station-products.co.uk/faqs/common-issues-weather-stations
Under £30 £30-£75 £75-£125 From £125 Birdhouses/Feeders Outdoor Clocks ... I'mnot getting any outdoor readings from my outdoor sensor, what do I do? This willcure 90% of all sensor connection problems, important you must ... is the airtemperature, to get this reading you need to place the unit away from direct sun.
www.acurite.com > All products
