Home Security Logo
R
Richard DiCecio Posted on Dec 02, 2017
Just had Kidde CO Alarm installed. Alarm is chirping every 30 seconds. model KN_COP_IC ERR code: E04 Can't get chirping to stop.
  • Jack oneal
    Jack oneal Feb 24, 2018
    Hi Richard DiCecio, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?how many timesmes does it chirp
Jack oneal
Level 1:
Habit-Forming:
New Friend:
  • Contributor 22 Answers
  • Posted on Feb 24, 2018
Jack oneal
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
22
Questions
Helped
5251
Points
47
How many times does it chirp
4 Related Answers
Anonymous
  • 1605 Answers
  • Posted on Dec 02, 2008
SOURCE: 1 chirp every 30 seconds
it is not the battery problem, you need to get a replacement.
the circuite board is bad.
tomandersen
Tom Andersen
  • Posted on Nov 23, 2010
SOURCE: The CO alarm started to beep every 30 seconds. I
They only last 7 years, after which they beep every 30 secs. You need new ones.
Anonymous
  • 134 Answers
  • Posted on Feb 01, 2011
SOURCE: MODEL KN-COP-DP MFG 2003 GETTING ERR AND BEEPING
If the display shows "Lb", the battery is probably low; replace it. Make sure you are buying brand-name batteries, EverReady, DuraCell, etc. not some cheap knock-off brand you may never have heard of. There is absolutely no quality control or minimum performance specifications for batteries that are marketed in the US and there is some REAL trash out there. If the display shows "Err", push and hold the Peak Level button. Does the display change to "E09"? If so, then you have just been "had" by the grossly under-documented "planned obsolescence feature" called, rather matter-of-factly, "End of Life". This means that ~7 years after first being powered up, the unit will, BY DESIGN, cease to function, forcing you to buy a replacement. Would have been nice of Kidde to include THAT warning on the OUTSIDE of the package. Call their "Hotline" at 1-800-880-6788 and tell them what you think of that policy. If it is still under warranty (5 or 7 years depending on date of manufacture) they should replace it. In any event, buy another one; if they replace your first one you will have twice the protection. Not a bad thing. *Disclaimer: I am not a lawyer, despite the handle. Words to live by: "Every creative act results from a sudden cessation of stupidity." -Edwin H. Land, inventor of the Polaroid Land Camera"The problem can always be solved with the materials in the room." -My college Physics Lab Instructor
Anonymous
  • 4736 Answers
  • Posted on Feb 10, 2011
SOURCE: I have a KIDDE /
Normally, that means the battery(s) need changing.. But, hundreds people have had problems with this combo detector, it's hard to predict what it is.
But, as I said earlier, "Normally that means the battery(s) need changing." The keyword here is "Normally".
Good luck. I hope that solves your problem.
Can you please help me find a manual for a kidde carbon monoxide detector? The model number is kn-cop-dp-10ybca (900-0282ca)
Past link below in your browser and scroll down to the documents tab that is just above the blue picture of the girl sleeping. Once you click that documents tab you should find the link to open the manual.
https://www.kidde.com/home-safety/en/us/products/fire-safety/co-alarms/kn-cop-dp-10yb/
Alarm went off but no smoke was found and no other smells were detected. I do not believe that there was CO present. All the units were activated. after a period of time they stopped. This occurred 3 times...
http://www.kidde.com/Documents/User-Guide-900-0102-A-ENG.pdf Remember that smoke take presidence over C/O detection so notice whats going off first . LED Indicator Operation
Red LED
The red LED will flash as described below under the following
conditions:
--During smoke or CO alarm, with every beep
--During testing (same as alarm)
--Low battery, single flash with chirp
--End of product life, double flash every 30 seconds with chirp
--Unit error mode, single flash with chirp
--Unit error mode, a Fault Code is flashed every 30 seconds (can
be observed and reported to customer service for
troubleshooting. Above is the user guide.
1helpful
Nighthawk carbon monoxide alarm model KN-COPP-3. ( ERR appears in the window, what does this mean ....
Readings You May See When Unit is AC Powered
Display Shows Alarm Sound Unit Status Recommended Action
Steady "Err" "Chirp" every Unit malfunctioning when Call KIDDE customer
and flashing dot 30 seconds AC powered service at 1-800-880-6788
Readings You May See When Unit is on Temporary Battery Backup
Flashing dot None Normal battery-only operation - Plug in to AC as soon as
unit will show reading only if it possible to conserve battery
senses CO
Flashing dot and "Chirp" every Unit malfunctioning when Call KIDDE customer
"Err" 30 seconds battery powered service at 1-800-880-6788
Hope this helps. Manual is here:
http://www.detectorsandalarms.com/images/pdf/Manual_KN-COPP-3_900-0100en.pdf
If this helps you resolve your problem, please consider giving a good rating and a quick thanks or good job.It will help me as well Thank you.
11helpful
3answers
My Kidde Model # KN-COEG-3 keeps going off and lists 217 now 205 now again 217 and this is with the door open and fresh air coming into my place ??
I took the following from the Kidde website. They only answer the phone Mon-Fri, from 8-5, EST. I checked it out because my almost new Kidde CO detector is showing an Error code.
The next time your carbon monoxide alarm has ERR on the display, push and hold the Peak Level button.You will see an E and an O followed by a number.Contact our hotline at 1-800-880-6788 and provide us the error code, along with the model number, assembly number and date of manufacture from the back of your unit.If your unit is under warranty, a replacement will be mailed to you.
4helpful
3answers
My CO detector is chirping every 30 seconds or so, there is no battery to change and receiving error code 09
depending on what model number you have .. if its a model kn-cosm-b then is actually has 3 AA batteries inside ... the model kn-cob-lcb-a, while it runs on 120 volts, still has a 9 volt battery inside .. in fact most models have a battery backup so that they still work if there is a power outage .. the chirp indeed tells you that the backup battery needs changing .. if you cant find the battery give us the model number and we can help ... sometimes they are hard to find ..
1helpful
3answers
What does an err code E03 mean?
the sense is bad, unfoturally the unit need to be replaced.
9helpful
4answers
Nighthawk carbon monoxide alarm model kn-copp-b
Here is a link to the manual, or you can call the consumer hotline at 1-800-880-6788
910helpful
11answers
Carbon monoxide detector err code
Detecotrs have a limited lifespan of 5-7 years. So sounds like you need new one (It's not worth to buy just a sensor). Take a look on amazon: Amazon com Carbon monoxide detector (watch out on reviews). I hope this was helpful. cheers
Top Kidde Home Security Experts
 Mikey
Mikey
Are you a Kidde Home Security Expert? Answer questions, earn points and help others
