Question about LG Dishwashers
LG Dishwasher runs to about half of cycle than code comes up on screen with FE
SOURCE:
  • 750 Answers
SOURCE: I HAVE A LG DISHWASHER
Hello jaq1407Welcome
You said, You HAVE A LG DISHWASHER IT ONLY GOES THROUGH HALF CYCLE AND COMES UP WITH HE?
Please send me the model number and year!
Waiting your response
Posted on Oct 22, 2008
  • 706 Answers
SOURCE: My LG dishwasher keeps stopping
Hello again annasgsds,
An FE error code signifies "excess error" meaning excessive water is supplied ..more than normal.. possible cause are the inlet valve ( which I made reference to in my previous response of the controller itself is damaged or defective. In either case.. LG recommends to replace the inlet valve or the controller once diagnostics are completed and you've identified which of the two components may be at fault. Could be either but before replacing the control card, I would remove and clean the inlet valve to see if that was clogged or dinged up and unable to fully close.
Regards,
Rick
Posted on Dec 02, 2008
blueextc3221
  • 15935 Answers
SOURCE: "FE" Error code on Lg Washer #2277HB
FE means overflow condition. That means sand or trash has gotten into the tube going from tub to water level switch. So find that hose and blow it out. Remove the standing water and retry.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
SOURCE: Dishwasher won't run much of the cycle.
LG dishwasher 2009 lds4821bb, water does not heat up anymore. thanks
Posted on Sep 17, 2010
  • 867 Answers
SOURCE: Lg dishwasher fe error code
This is a fill error, check your tap is on and that the inline filter screen is clear, if all is good then you have an inlet solenoid issue.
Posted on Mar 05, 2012
I replaced the filter on my LG dishwasher, model LDS 5040ST and after attempting to run it Igot an FE code?
FE means FILL ERROR. Usually cleaning the floats will fix this issue. Just follow the instructions from the video.
Jul 27, 2018 | LG Dishwashers
LG dishwasher LD1419W2 which would not fill -error code IE. I replaced the inlet hose complete. Now it has the error code FE and the water overflows onto the floor when in wash cycle. Peter
Try resetting by:
turn off dishwasher
trip circuit breaker to remove all power to unit
wait 30 seconds
restore power
start dishwasher
the drain pump should start and drain all water then start a cycle. Good luck
Nov 14, 2017 | LG Dishwashers
Why on an LG Front loader does the FE code come on and not on Rinse & Spin?
Here is the LG site for washing machine error codes, you can scroll down and find the FE code there:
http://www.lg.com/us/support/product-help/CT10000010-20150140270078-other-error-codes
The site shows the following:
The FE error code indicates the washer is overfilling. This is usually the result of a faulty water valve.
1. Close both water taps.
2. In order to drain out any trapped water, power the washer back on and press the Spin Speed button until No Spin is selected and press the Start/Pause button.
3. Once the washer has drained, restart the wash cycle.
Jan 26, 2017 | LG Washing Machines
Dishwasher blockage
there is a removeable filter at the bottom of the wash pan. It is usually a "screw-in" type of ring. See if this website can help..
www.applicancerepair.com -enter your make and model and search
Feb 12, 2015 | LG 24 in. LDF 7811 Stainless Steel...
When the wash cycle is going it starts to make a tune and then FE starts flashing I need to know what FE means
Hi there Celina the code FE has a few differant meanings depending on the dishwasher model. If you can provide me with the model code I can help you with this problem.
Nov 21, 2011 | LG Dishwashers
LG DISHWASHER LEAKING WITH E1 ERROR CODE.
Hi phtanner,
The E1 error can be fixed by following my Tip below:
L.G DISHWASHER E1 ERROR...
Follow these directions, and the problem will be fixed.
Kind Regards :-)
* If this solution helped you, please rate it.
Jul 28, 2011 | LG 24 in. LDF 7811 Stainless Steel...
Lg dishwasher smells
Please perform an vinegar clean cycle on your dishwasher..Pour a half cup of vinegar into the bottom of the dishwasher and run a cycle at the highest temperature possible.Run the complete cycle.. Also clean the dishwasher filter for debris if any.
Dec 10, 2010 | LG 24 in. LDF 7811 Stainless Steel...
Jan 26, 2010 | LG Dishwashers
I HAVE A LG DISHWASHER IT ONLY GOES THROUGH HALF CYCLE AND COMES UP WITH HE?
Oct 22, 2008 | Dishwashers
Dishwashers Logo
284 people viewed this question
Top LG Dishwashers Experts
Marvin
Marvin
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
