Question about Humminbird Boating
My humminbird 998 does not always shut off when in shut down mode
Raymarine C90w Chart Plotter replacement cursor - where can I get one or what's a substitute fix?
I wonder if you could use the C80 cursor from this one on eBay?
Raymarine C80 GPS FOR REPAIR or For Parts BAD SCREEN eBay
If not, technology moves on. I love my Humminbird 998 HDSi.
Apr 28, 2018 | Raymarine GPS
Can I view on computer?
No Alice, you can't. The only thing you can do is put an SD memory card and put it in the unit and save screen shots for viewing on the computer. To update the firmware and programming, you load to an DC card on the computer and then insert it in the unit. The unit always remains on the boat.
I had the 798CSi, and now have the 998 HD.
Dec 11, 2015 | Humminbird 898C SI Side Imaging Combo 7...
I have a Humminbird fishfinder 525. It goes directly in simulation mode and says: No svinger connected... What could be the problem?
If the transducer is disconnected, it will automatically go into Demo Mode.
If you do have the transducer connected, but the boat isn't in the water, the unit knows there is no water and after a few seconds, switches to Demo mode.
Not sure what a 'svinger' is, but if you need more help, just ask. I can also edit the message and change 'svinger' to something else.
I have had both the Humminbird 798 and also the 1198HD. They are great pieces of kit on the water. The 525 is entry level.
May 10, 2015 | Humminbird 525 Fishfinder
My Humminbird 535 will not exit out of Simulation Mode. How do I fix this problem?
click menu twice scroll down to (unit) click on it scroll down to simulator mode see if its on if so click on it turn simulator off
Oct 25, 2013 | Humminbird Boating
My IPad worked well with Navionics untill few days ago, then following problem appeared: when running my boat with trolling speed ( like 2 mph) the screen shows my position on map with the red arrow and...
Go into Settings - Navionics App and make sure that Mobile Data is enabled and also Background App Refresh. Finally, Location set to Always. It sounds like it is not being updated, but just setting your position on opening.
It is not a particularly good app and very basic although I have not tried the Paid version. I have a Humminbird 998 HD Side Imaging and the Navionics Mappind SD Card which gives much better results.
Aug 05, 2017 | Lands Phones
Sc 998
"Application Start Error". Try "Yellow Key", 1, 0, 7, then Orange Key. When it goes into service mode, shut down, unplug for 15 seconds, then plug in and turn on. If that does not work, call service.
Mar 02, 2011 | Ricoh Office Equipment & Supplies
Humminbird 565 says its loading
You'll need to take this one to an authorized service center to have them have a look at it. My guess is that the software is corrupt, so it may just be an easy fix. You can try it yourself if you like (if it's out of warranty). Go to www.huminbird.com and register your sounder. That will give you access to the software updates and instructions.
Best of luck!
Mike
Mar 31, 2009 | Humminbird Fishfinder 565 With Transom...
Portable Humminbird 565
I've got the 565 and everything will be working fine and then the depth
finder or bottom of the lake goes to 6ft. Have to shut it off for an hour and it works for a wile but it always goes back to doing it
anything I can do?
Thanks Jeff
Aug 24, 2008 | Humminbird GPS
Boating Logo
71 people viewed this question
Top Humminbird Boating Experts
fordexpert
Bill Eager
Mike
Are you a Humminbird Boating Expert? Answer questions, earn points and help others
