Electronic Compass
The compass display and module are contained in the overhead console and are replaced as an assembly. For additional information, refer to Section 501-12 . The compass display can be turned off and on by pressing the MODE button in the overhead console. The vehicle heading is displayed as one of N, NE, E, SE, S, SW, W, or NW.
Inspection and Verification
NOTE: Press the MODE button to turn on the display.
Visual Inspection Chart
Mechanical
Electrical
Pinpoint Test A: The Compass Is Inaccurate/Inoperative
Normal Operation
The compass receives battery voltage from the central junction box (CJB) through circuit 964 (DB/LG). Ground for the compass is supplied through circuit 676 (PK/OG).
Possible Causes
PINPOINT TEST A: THE COMPASS IS INACCURATE/INOPERATIVE
NOTE: Always set the zone and calibrate the compass before replacing an inaccurate compass.
NOTE: After installing a new compass, always set the zone and calibrate.
Test Step
Result / Action to Take
A1 CHECK THE OVERHEAD COMPASS DISPLAY
Yes
GO to A3 .
No
GO to A2 .
A2 CHECK THE COMPASS MODE
Yes
If the compass display turns on correctly, GO to A3 . If the compass display turns on, but the heading is inoperative/inaccurate or the display indicates VAR, GO to A4 . If the compass display turns on, but it does not display all directions, or indicates CAL, GO to A5 .
No
GO to A7 .
A3 CHECK THE COMPASS DIMMING
Yes
TURN the headlamp switch to the OFF position. GO to A4 .
No
TURN the headlamp switch to the OFF position. GO to A8 .
A4 CHECK THE COMPASS ZONE SETTING
Yes
GO to A5 .
No
INSTALL a new overhead console. REFER to Section 501-12 . TEST the system for normal operation.
A5 CALIBRATE THE COMPASS
Yes
GO to A6 .
No
A6 CHECK THE COMPASS ACCURACY
Yes
The compass is OK. REVIEW the operation of the compass with the customer.
No
A7 CHECK THE VOLTAGE SUPPLY TO THE OVERHEAD CONSOLE
Yes
TURN the key to the OFF position. GO to A9 .
No
VERIFY the CJB fuse 15 (7.5A) is OK. If OK, REPAIR the circuit. TEST the system for normal operation.
A8 CHECK THE DIMMING CIRCUIT
Yes
GO to A9 .
No
REFER to Section 413-00 for further diagnosis of the instrument cluster and panel illumination.
A9 CHECK CIRCUIT 676 (PK/OG) FOR OPEN
Yes
No
SOURCE: 2007 Mercury Grand Marquis required oil weight
If u have a moderate climate, 10W-30W, if cold climate 5W-30W, do not use any heavier weight of oils.
SOURCE: emergency fuel shut off switch for 1992 mercury grand marquis
It is in the trunk I can remember which side on a 92 but it will be behind the side trim panel almost straight down from the trunk hindge.
SOURCE: rear shocks on a 1996 Mercury Grand Marquis
2 bolts on the top of shocks and 1 bolt on the bottom but the top 2 bolts are a pain in the neck
SOURCE: Mercury grand marquis 1997 temperature control
I'm not sure if yours is identical to mine since yours is second gen and mine is third gen, but with mine (1998 MGM), the heat was stuck on all the time. Full heat would practically cook your feet and you couldn't shut it off.
It was a servo/servo arm that controls the hot/cold mix door. The part was $15. The labor was $700. They had to take the entire dash out of the car to get at the part. Required two more visits due to a missed electrical connection to a daylight sensor and a vacuum issue that made the car stall when put into reverse.
My car had 150K on it at the time. Has 165K on it now. Still runs great and looks great. It's now my wife's auto and I drive a 2006 MGM.
SOURCE: how to replace starter +1993 Mercury Grand Marquis
disconnect battery,,jack car up,,put jack stand on frame,,take starter bolts out,(may not be easy),,take wires off starter,,hoped it helped,,
