SOURCE: cant find how to tilt evinrude outboard
have you got hydraulic trim/tilt? if so control button /switch will be on or near throttle handle-if not you will have to manually lift and insert pin at bottom of mount on transom
SOURCE: 1967 evinrude sport 4 60hp wiring diagram
That came with either battery or magneto. If the distributor is rather shallow and the ignition wires cross the middle of the cylinder head, it is battery, if the ignition is long and the wires cross above the thermostat housing- it is magneto.
That is one of the great historic motors made, but carry lots of gas!
Replace coils after checking each one
Testimonial: "Thank you"
