E-Z-GO Golf Cart Brake Shoes - Genuine E-Z-GO Parts and Accessories
https://shop.ezgo.com > Shop > Parts > Brake Parts > Brake ShoesOEM Golf Cart Brake Shoe 4084 ' Single Shoe. Fits 1996-current E-Z-GO Golf Car and Utility Gas & Electric Vehicles. Item #: 648037. $24.70/ea. Spring- Shoe Return- LH (Blue). Used on 1996-Current E-Z-GO Gas & Electric 4/6 Passenger Shuttle, ST Express, 875, 881, 950, and Cushman Titan Vehicles; in addition to ...
SOURCE: REAR BRAKES
i think your aware of how to change the brakes if im right and your problem is the rusted drum doesnt want to come off the only way to get the old drum off is to remove adjuster plug from behind drum dustshield and adjust the shoes so that there not even close to the braking area of the drum then try and wiggle the drum off of the assembly if it is not coming off then you need to use the old nylon hammer on the drum and i mean you must hit the drum from side to side trying by hand to wiggle the drum off its a tight fit and you need to strike the drum on the face not on the fins not wanting to damage with persistance and care and patience you will eventually be able to remove the drum to service brakes take care and good luck with it
SOURCE: rear brakes uneven breaking as per mot tester
The Chardes have a diagonal split system, so one of the front discs is plumbed to the diagonally located rear drum.
You may need to check the front brakes too and that they have been bleed properly.
Other common cause of uneven braking are:
seized wheel cylinder;
brake hose obstruction or weakend wall;
weak pull off spring on shoe;
uneven drum roundness;
compensator/proportioning valve dicky.
SOURCE: Ford Focus Brake shoes
You need to remove the axle nuts to get the drums off. Left side may have left hand treads.
SOURCE: how to change rear brake shoes on a 2004 chevy venture
The rear brake shoes use a U clip to hold the shoes together. A simple solution to this change job is to change one side at a time.
Slowly unclip the U clip from the top of the shoe and remove the left shoe and spring. Replace the left shoe and reconnect the U clip, then do the same for the other shoe. Clean, adjust,and grease the self adjuster and you're done. Do the same for the other side of the van. If you take both sides of the clip off you're in for some heavy duty stretching with pliers unless you have the right tool.
SOURCE: Rear axle fluid for 1983 ez go electric golf cart?
Regular 90 weight gear oil. Fill until it reaches the fill hole.
Hank, The cart man
