Music Logo
Mike Stewart Posted on Nov 30, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can anyone tell me how to adjust the pitch bend range on a Roland JV 2080?
James Kovacs
Level 2:
Champion:
  • Expert 219 Answers
  • Posted on Dec 14, 2017
James Kovacs
Expert
Level 2:
Champion:
Answers
219
Questions
0
Helped
87815
Points
305
Software, download the Owners Manual and get into it.
1 Related Answer
Anonymous
  • Posted on May 19, 2009
SOURCE: i would like to change the pitch bend range in
Hello :) I can help you :) First of all,press menu button.Then,on the screen touch MIXER TUNING.Then at the bottom of the screen press TUNING,and you'll find PB sensitivity.And then touch the number one the screen,which appears under PB sensitivity.At the end,just scroll tempo/value dial from 2 to 12 :) That's simple :)
1helpful
How do I do transposition in e16 Roland?
To transpose a sound on the Roland E-16 keyboard, you can use the Transpose function. Here's how to do it:
  1. Press the FUNCTION button and then press the TRANSPOSE button.
  2. Use the + or - buttons to select the number of semitones you want to transpose the sound. The range is -12 to +12 semitones.
  3. Press the EXIT button to exit the Transpose function.
Once you have transposed the sound, it will be played back at the new pitch. Keep in mind that transposing a sound may affect the overall tone and timbre of the instrument, so you may need to make additional adjustments to achieve the desired sound.
Mar 19, 2023 • Music
My screen is out on my roland jv 80 keyboard
This problem will require servicing. The screen is bad, and has to be replaced.
Pitch bend issues
Hi, try to find how to reset it or go to default mode,find out in the users manual.Hope it will solve your problem,
I need to know how to raise and lower the pitch
In principle, the primary oscillator needs to be adjusted- some keyboards have a pitch or bend control that if not set correctly, it will affect the tone of the entire piano.
Apr 05, 2012 • Music
Roland jv-90 button repair
I.m looking for all the ROLAND JV-90 plastic push buttons.
How can I fix a pitchbend that doesn't work at all on a ROLAND JUNO 2?
Some have found that doing a "Factory Reset" has cured an inoperative pitch bend control.
If that doesn't work, inspect the control for mechanical damage and replace broken parts as needed.
Mar 21, 2011 • Music
Got a Roland GW-8. I've had it for almost a year and a half. The problems consists on the fact that the keyboard gets out of tune while playing. Its not even a full note. After that I have to shut it...
OK... It is literally impossible for the unit to "go out of tune" as it is crytal controlled... HOWEVER what is probablly happening is the PITCH BENDER is getting into the mix somehow.
If the centering on the pitch bend control is sticking or is loose, this would likely be the problem.
Do some tests with the pitch bender to see if you can detect either a mechanical or offset condition of the control.
1helpful
Sometimes I face problem with my bendar. If I move it, it changes the pitch. To bring back to normal pitch,I have to move it couple of times. When I try to bend a sound which I used to bend always before,...
It sounds like the knob on the pitch bend control MAY be loose on the shaft or on the mechanism. Since this is a higher value unit, if you are NOT electronically adept, best to take this in for repair... It is probably a simple problem, but opening one of these can damage cables if you are not familiar with the unit.
Top Roland Music Experts
NOEL
NOEL
Are you a Roland Music Expert? Answer questions, earn points and help others
