Is it auto defrost model? Any frost build up in inside back freezer wall? If so, you have a defrost problem.
There should be a temperature adjustment inside the freezer somewhere. It will look like a slider or a dial, and be labeled something like "Colder" and "Less Cold" on opposite ends of the scale. If this is set to its coldest setting, and the temperature still is not cold enough to solidly freeze food (ideally, a freezer's temperature should reach ZERO degrees Fahrenheit), then the unit needs to be serviced by an appliance repairman.
SOURCE: Amana Freezer not running
Take something and plug in wall socket to make sure you have power to the reciptical... somethng that new .. seems like you have ...NO power to it.. do u have a light in freezer and does it come on inside the freezer???
SOURCE: Proline FS 707 Upright freezer -problem
Check that the air vent is free from anything blocking it at it maybe over heating.
Thanks J
SOURCE: FRIGIDAIRE UPRIGHT FREEZER ONLY 2 BOTTOM SHELFS FREEZING
someone suggested to me the other day to put weter foods closer to the top the ones with dripin water and more solids down at bottom they said this changes the climate inside to be more economical
im just passing this info cause ive never had or been in contact with a upright freezer
SOURCE: FREEZER ALARM WILL NOT SHUT OFF
You can try 2 things. Unplug it for about 2-3 minutes and then replug it. It should reset itself. You can silence the alarm or muffle it. Silencing it should be hard. Disconnect it from its source. You may want to find out why it is alarming constantly. Have you called Sears and asked them?
SOURCE: Frigidaire upright freezer Model #FFU17C3AW1 Not keeping cold
Yes that is the correct part number.
If a new cold control does not correct the problem. Replace the compressor start relay.
