I'm not for sure but my suv has low and to get out of it u have to put the trans. in N wait a few then move the switch to 2 wheel and it switches. hope this helps
Take the bottom off and there may be a round cylinder that should be filled with oil and a cap that screws off. Remove the cap and I think there is a clip that needs to be removed.
7,010.43 Printhead is stuck or is not tilting properly over the cam.
Initial Actions • Check that the Process Drive gear train is properly homed. • Check for obstructions or ink spills around the Printhead. • Verify the Printhead travels smoothly from left to right. • Check the Printhead Restraint Arms. • If the problem persists, follow the procedure below.
Table 1 7,010.4x through 7,015.4x Troubleshooting Reference Table Applicable Parts Wiring and Plug/Jack References Process Drive, PL 4.0 Right Side Harness / I/O Control, Figure 8 Head Tilt Solenoid, PL 4.0 Left Side Harness (2/2), Figure 5 Head Tilt Gear, PL 4.0 Restraint Arms, PL 2.0 Head Maintenance Clutch, PL 4.0 I/O Board (2/2), Figure 10
Table 2 Printhead Restraint Fault 7,010.xx through 7,015.xx Troubleshooting Procedure Step Questions or Actions Yes No 1 Reboot the system.Does the error persist? Go to Step 2. Complete. 2 Check the Printhead Lock Arms. Go to Step 3. Repair or replace Do the arms rotate correctly? the Printhead Restraints 3 Check for ink spills around the Printhead Go to Step 4. Remove ink spills or obstructions. and Printhead Tilt Gears. The Printhead should move when pushed left or right. Is the area around the Printhead clean and unobstructed? Remove ink spills or obstructions.
You need to master reset the phone, you can do this by Settings > Phone settings > Reset settings if this does not work you need to update the software by visiting this link: http://uk.lgmobile.com/web/web.support.retrieveSoftwareUpdate.laf" style="color: blue; text-decoration: underline; ">http://uk.lgmobile.com/web/web.support.retrieveSoftwareUpdate.laf
Machine shd be on. Press and hold "end of cycle" button for 3 seconds, on the right side
of panel. Try door after 2 minutes. This is the child lock feature, do
it again & it locks.
