I purchased this game and installed it in my previous computer which has since been replaced with a new computer and operating system. can't get it to load because activation was used to activate on older computer
SOURCE: Operating System Problem
Did u format HDD in installing Vista? If not, it means the system had dual boot, and XP boot file was missed. u have to fix the boot file to support dual boot completely.
SOURCE: " Error loading operating system "
This is not an easy one. But to start,when you install an OS, you needed to delete the drive when you where at the install screen of windows,which you did not post which one. Then after you install an OS
you need to install the chiposet drivers for the motherboard so that it can work. Then the graph drivers,sound drivers,lan drivers. If you do not install the drivers for the hardware that is on the Mobo
windows will try and use generic drivers which are junk.
So you are going to download the drivers for all the things I said. Now when you try and install and you are at the screen that ask to install windows, look down and pick delete the partition than pick which ever letter it ask for and pick yes, now you will see to create new partition, just hit enter because
at the box on the bottom of screen has the full size of the hard drive in it, unless you need to make another partition. Now make sure that C- new raw -- is highlighted and hit enter to install windows to your hard drive, now you get- format NTFS , do not format quick.
This is the best way to install a OS on a clean hard drive. Hope you get it installed ok and all the drivers.
SOURCE: Installing VIP Customizing on new
I have a new computer with Windows 7 and kept getting "no dongle" message each time I tried to open Vip Customising
or 4D Organiser. The dongle is purple with Rainbow Superpro
marked on it. I downloaded file - Sentinel Protection Installer
v 7.6.3 from http://www.suesbayareasewing.com/win7.html.
Both programs now operate. Once you have installed the
software carry out a restart and then plug in the dongle. Windows 7 should then install the driver and hopefully you
will be back in business as am I. [email protected]
Windows operating systems require a valid product key in order for them to work. You would have to purchase WinXP in order to get a product key. Unfortunately, WinXP is in its last days of its product lifecycle and will not be supported. You'd be much better off trying to install Win7.
Buy Windows 10 Activation Key 64bit 32bit
http://www.Genuinewindowkey.com/
Aha, same question as what I raised several days ago. I bought a new computer and the new operating system is Windows 8.1 activation key. When I tried to activate the system, it prompted me that I need to have a product key. I asked friends and one of them recommended me the site http://www.Genuinewindowkey.com/ from which I could easily order a product key. Then, I just followed his advice and really activated my system with the purchased product key. It didn't cost much and bought me a convenience service.
