Download the latest drivers from the manufacturer websites rather then relaying on the old cdroms - they are probarbly outdated and made for XP.
SOURCE: I have a brother printer,
The Automatic Private IP Addressing (APIPA) protocol
automatically assigns an IP address from the range:
169.254.1.0 to 169.254.254.255. If the APIPA protocol is
disabled, the default IP address of a Brother print server is
192.0.0.192. To change it, use the printer control panel (if
applicable), the BRAdmin Professional, Web BRAdmin software
or let your DHCP server allocate an IP address to the printer.
2 Refer to chapter 10 of this User’s Guide to learn how to
configure the IP address on your printer.
3 The default password for Brother print servers is access.
4 Windows® 2000/XP users can print using TCP/IP using the
standard Network Printing software and IPP protocol software
built into any Windows® 2000/XP installation.if you need manual just email me at [email protected] or [email protected]
SOURCE: I need to add the dell Photo 924 printer to my lap top
You can download the drivers you need here.
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&os=WW1&osl=en&catid=&impid=&SystemID=PRN_ALL_A924
SOURCE: trying to connect lap top
The WEP key is something you designate on your own router. IF you are trying to get into someone else's router you need to ask them for permission to have their WEP key. Otherwise you cant get in. If you forget your WEP key you can do a hard reset on the router to clear out the key.
SOURCE: hi i am trying to
Welcome to FixYa! I believe that when you're trying to connect wirelessly it's not asking for the network key or other users are able to connect to your network. Please follow the steps below for you to be able to make your connection secure.
1 Open your web browser, type " http://192.168.1.1/ " into the address bar and hit "Enter."
2 Use "admin" as the username in the pop-up box and leave the password blank or try to use " admin" as the password as well.
3 Connect to the Internet and click on "Internet Setup."
4 Select your connection type from the drop-down menu. Choose "DHCP" for cable modems or "PPPoE" for most DSL modems. If you are unsure of these options, check with your ISP.
5 Set a service set identifier (SSID) to identify the router and change the password.
6 Encrypt your wireless connection using a Wireless Encryption Protocol (WEP) key. Under the "Wireless Security" option, enter a passphrase and click "Generate." This will generate a password which will need to be used by any client connecting to your router
Hope this will help...Thank you for using Fixya...
