SOURCE: Compatability issues with new Ryobi Lithium Ion Batteries
i have the same problem and have returned once for replacement charger and battery, still no working well help [email protected]
thanks
SOURCE: Will the ryobi nicad charger also charge the
No, but the Lithium charger will charge the NiCads.
SOURCE: Does it harm a Ryobi 18v lithium battery to leave on Charger?
Lithium-Ion batteries require careful charging and temperature monitoring while in the charger. Ryobi's Charging station monitors many functions and shuts off when the battery has gone through a complete charge. This is indicated by a steady Green light. Once the Charge indicator is a steady green the charger stops charging. With any battery It will slowly discharge and I don’t think the Ryobi will maintain a battery that is never removed. For example, if after a complete charge cycle if the battery was left there for 2 years and then you went to use it, it would likely be completely discharged. However if the battery charger is unplugged then plugged back in a new charge sequence would start. I lose power at my house about every 6 months or so. Once power is restored a new cycle would start and the charging cycle begins again.
Hope this helps and have a great day.
Testimonial: "This is the best answer I received! Thanks!"
SOURCE: can you charge ryobi lithium batteries in a
NO! Never charge lithium batteries in a charger designed for nickle based batteries like the NiHi your old charger was meant for. Ryobi did design the new Lithium charger to be backwards compatible so you can charge your older 18V NiHi batteries in the Lithium 18V charger.
Also note, NEVER miss-match the voltage, for example, make sure you are not trying to charge 12V batteries in an 18V charger unless the manufacturer has specifically stated that the charger is capable of multiple voltages.
SOURCE: ryobi lithium batteries won't take charge
For others with the same problem (flashing red light won't go off)...make sure you FIRMLY PUSH the battery down onto the charger and engage the latches. Simply resting the battery on the charger will not work.
