You have a power output section failure. It will require service, if you can not find a problem with speakers and/or speaker wiring. Disconnect all speakers and see if error goes away. If not, your failure is inside the unit. Goes away? Double check as above.
The service manual can be found at hifiengine. Go to Library and scroll down to panasonic (click). Then scroll down to audio video systems and click. Scroll down again to your model sa-kx32. Download &open manual and use contents page to find error codes. You may to open a FREE account to get that far, but manuals here are free.
SOURCE: Panasonic SA VK550 - F61 eror
Hi, i had the same problem with a panasonic player, when you see the code F61 in the screen it is because the audio output IC is defective,change that and the set will work perfectly. hope it work.
SOURCE: POSSIBLE FAULT CODE
Yes, it is possible. The F61 error is a failure in the power supply or the amplifier. I repair these every day and it will require good soldering and troubleshooting skills to fix this yourself.
If you would like to try, let me know, and I will give you more information. But the best thing to do is take it to a service center and let a professional technician check it out for you.
SOURCE: panasonic surround sound system model # sa-ht95
Error code ' F61 ' on most Panasonic models indicate that the built-in diagnostics has sensed a fault at the output stage. This would normally refer to a failed output amplifier IC (?P/N RSN704D66P?). In some instances, the fault could also be triggered by:
Options then are:
Good luck
SOURCE: Error F61 on Panasonic Stereo System SA-AK80
HELLO
As far as I can know, F61 means your output IC is dead. Contact a service centre in your locality for repair!
