this site is the maker but the link is for a different model. however they have a link for support so go here and ask them what issues having and they may be able to help you. good luck.
To operate the slicer in Automatic mode . . . Rotate the Speed Selector Knob to the desired
speed; make sure the Carriage is in HOME position (all the way forward); make sure the Lever
is on the Manual position (pointing down); turn the slicer on; start the carriage drive unit by rotating the Lever to the Automatic position (up and to the right).
Either of the two speed selections can be used to begin Automatic mode. The speed can be adjusted
at any time by rotating the Speed Selector Knob.
To stop the drive unit, rotate the Lever down and to the left - to the Manual position.
If you slicer is set on proper automatic mode and still not running on automatic mode then the problem relates to internal motor or the selector knob.
But try reset before this.
Push the reset button underneath the slicer near the right-front foot if the carriage motor overloads.
The reset helps in some problems.But if its not helping then internal connections of selector knob has to be checked.Of the same with motor,the connections of motor to the selector for automatic mode has to be checked.----------------
This will help.Thanks.Helpmech.'
I also bought one at a yard sale, complete and in the box. It did not have a meat tray with it, nor a picture of one on the box, nor any mention of one in the instructions. I just use a plate, and it works fine. Sorry.
