SOURCE: Seagate Hard drive
There is a problem with EXTERNAL.Hdd is fine just buy new external and it will work fine again;)
hello..the problem is just sticky tack switch's so try to clean or re-align the frame/body of LCD..Thanks.Good Luck..^_^
SOURCE: Toshiba Satellite A205 laptop will not boot - black screen
Here's a link to a good article that will help you to troubleshoot the startup error. You might also check Toshiba support online and see what the error light code indicates.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
SOURCE: Dell Dimension 2300 - Boot Up Issue - Replace Motherboard?
I have issues after shipping with wires. Have had to pull and reset wires with the computer unplugged and 80 % of the time that has fixed the problem.
Testimonial: "The suggestion was helpful - together with another suggestion, it helped advance the ball. Moving on to another issue now. Thanks."
