Hi there.
Sink A Self-Drilling (Threaded) Anchor
Fix-It Friday: Anchors Aweigh! How To Put Anchors Into Walls
womenyoushouldknow.net/fix-it-friday-anchors-aweigh-how-to-put-anchors-into-walls/
How to Install Drywall Anchors to Hang Heavy Stuff on Your Walls
How do hang an object using drywall anchors Google Search
SOURCE: How to I remove anchors- get a toggle bolt out of drywall?
unscrew the bolt until the toggle falls off into the wall cavity. Then just pull out the anchor and spackle over the hole.
A molly bolt is a similar type of wall anchor. It's often confused with a toggle, but a molly's "bendable" legs are part of the anchor and will remain in place when the bolt is removed. Sometimes you can straighten those legs out by unscrewing the bolt partway, then pushing it back into the wall cavity. If you're lucky, you might be able to pull the anchor out through its own hole. If not, you'll have to use a punch and hammer to pound the head just below the drywall surface, then spackle over it.
(http://www.thisoldhouse.com/toh/asktoh/question/0,,1585873,00.html)
