When I start the compressor it runs until desired tank pressure is reached as shown by pressure gauge A. However, pressure gauge B working pressure shows 0 psi. What am I doing wrong?
Pressure gage A shows the pressure in the tank. Pressure gage B shows what you have adjusted the output pressure to be. If it is reading 0psi and it is new it is probably because the manufacturer has set it at that level. You have an adjustment valve on the front of your compressor. Rotate it until you see the pressure start to rise then keep going to where you want it set at.
SOURCE: how do make air compressor shut off at your desired air pressure
You compressor has a pilot valve that controls the tank pressure and the speed of the engine. Locate the brass pilot valve, (It has a flip lever that unloads the compressor) you will notice that it has two locking nuts that allow for adjustment when loosened. Loosen the small lock nut and turn the upper-most part of the pilot valve out to reduce pressure, in to increase pressure. Hope this helps, enjoy.
SOURCE: Air compressor motor stalls under pressure
this sounds like a bad pressure switch.if the unit is not shutting off at the same pressure each time this would be the cause.2 if the pressure is not unloading the air pressure on the compressor side of the unit it will cause the unit to struggle when it starts a cycle because the piston is under a load .how this works is say the unit starts from 0 psi when it get to the desired pressure you have it set on the unit kicks off . the other adjustment most units have on them is what pressure to cycle back on.so when the unit reaches say 100 pounds ,it kicks off and bleeds the air off the compressor side so when it starts back up it wont start up with pressure on the piston.
SOURCE: I have a Sullair 185 air compressor. The engine
your not return balve is stuck open or your valves are sticking the pressure from the tank is going back to the pump so when the compressor goes on the compress stroke its very hard as it has to open the valve with pressure behind it its hard to explaing buddy but on the tank you wil see anon return valve from the pump unscrew it and inside is a rubber with a spring turn the rubber around and try this if doesnt work you need to inspect the valves (if sticking) good luck
SOURCE: my porter cable c2002 150 psi gal compressor the
According to Porter-Cable (Delta) themselves, they had lots of bad regulators on these compressors. I'm waiting for one myself. Same issue
