SOURCE: Power light cycles to red, no other lights on
Hi der... well the issue your facing is simple to say ur power adaptor
is faulty. Usually its due to some electrical shorts or maybe some
heavy lightnings. You can always have a remedy for it.
1st : Buy a new adaptor.
2nd: call ur ISP to have it replaced if ur still under some contract term or if the modem is still under warranty.
3rd : you can buy ur own ADSL2+ modem from supporting outlets . Make sure ur isp supports this modem.
This are the solutions for ur problem pal.. So make a wise decision..
Any needs and help post it to FixYa..ANd the experts here will fix ya..!
SOURCE: Sony Grand Vega green light blinks on and then blinks red
Please intimate exact model of your Sony TV and also mention how many times red light blinks as there would be pause of 3 seconds in blinks so count pause to pause and let me know to find out problem.
How old is this TV and did you replaced its lamp?
Thanks.
Testimonial: "You are on the right track even with my poor explanation. Thank you"
SOURCE: My SXRD 60
Perhaps it needs the bulb, but there is also a good possibility that the lamp fan is getting clogged and shutting down the set. This is NOT the fan you see in the back, instead, it is above the lamp, and is a small blower-type fan, that tends to clog with dust. You CAN check this, when you open the lamp door,you can see the blower wheel, and if it is all dusty, it needs to be cleaned out--but do NOT just blow it out, or you might clog the engine!! It needs to be removed, and cleaned out of the set.
But first...if the blower is not too dirty...try another lamp.
SOURCE: westwall modem Internet is solid red light
If the internet light is red, it means that the modem cannot get an ip connection from the ISP.
If your ISP has a PPPOE connection, most likely, the PPPOE password is not correct.
To ensure your settings, access the modem through a web browser. In the address bar, type 192.168.1.1.
Default Username: admin
Default Password: password
If this doesn't work, try admin for the username and password. If still doesn't work, you will need to reset the modem. Just hold the reset button for 30 seconds. Then turn it off for 1 minute.
Try again to access the modem, under Configuration, click Edit beside My Connection. Type your ISP username and password then Save.
Hope this helps! Good luck!
