The 80-KB2098 Batch # 115590 that i received only has 1 front wheel and 3 rear wheels which will not work for the front. How can i get a new front wheel so we can use this product. It came with no phone numbers or any information to be able to contact anyone, they are made by Trademark Global if any one can give me a number to contact or e-mail would be much appreciated Before Christmas
Why not contact who you bought it from? Or Google the make/model and see who sells it (including Sears, Target, etc. Contact their parts dept. Contact info for Trademark Games: Trademark Games Inc Company Profile Bloomberg
You tried all of that and what happened? Why would the seller would not rectify the error? You must know who sent or sold it to you. Were you not able to get any contact info from the shipping warehouse? Can't a place that sells them help you? It's not possible to give you assistance when you don't help with better information.
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
Testimonial: "I have tried all of that and the link that you sent me goes to a shipping warehouse, and they won't help me."
SOURCE: 1997 yamaha timberwolf 4 wheel drive only front wheel drive work
check to see if driveshaft to rear is turning.if it is, either the ring gear & pinion gear in the differential are not making good contact either from being worn, or out of alignment due to worn bearings in differential case,or both.check if axle has back & forth play in differential,indicating worn beaings. also could be worn ring gear to axle contact in differential.check for vibration in axle while in gear increasing as you give it more gas, caused from ring gear teeth slipping past teeth on axle.they would have to be replaced together. oversize wheels & tires tend to accelerate axle/ring gear contact teeth.
SOURCE: hearing noises from the driver side front and rear wheels
Jack up that side of the car and turn the wheels by hand to narrow down where the noise is comming from. You may have binding of brakes, if you are driving slow down the road and let the steering wheel go does the car pull to one side ? does it get worse if you touch the brake ? If it does, check the front.
SOURCE: torque setting for front wheel spindle and rear wheel bolts
http://www.carlsalter.com/download.asp?fileid=066077087095095082049049053048071083032082101112097105114095077097110117097108095050048048048046112100102
It's the service manual for the 1150GS, but the figures are the same.
SOURCE: rear wheel brake lock-up
1995 Monte Carlo rear tires locked up ,goes into gear but wont move?
