Http://www.partsdrop.com/techinfo/7328_Tech_Info_Sheets.pdf
http://www.support.xerox.com/support/workcentre-7328-7335-7345-7346/videos/enus.html?&associatedProduct=workcentre-7328-35-45-46-built-in-controller
The first link should include the information you seek. You may find the second link handy for support.
SOURCE: Xerox workcentre 265 waste toner full msg
Clean the sensor where the waste toner bottle goes in and just turn the copier off for a couple of minutes then turn it back on. The system needs to reset.
SOURCE: I have a Xerox XD125F Workcentre. The J2 toner
1. turn off XD125f
2. Turn on
3. within 4 seconds press, clear, auto, clear, auto. LED Should go blank,
if not try again
4. use copy quantity keys to enter 24, then push start
5. Again use copy quantity keys to enter 7, then push start
6. turn off
when you restart the cartridge count will be set to zero
I have done this twice and never replaced the drum cartridge.
SOURCE: our xerox workcentre 7328 shows fault code 004-346
I don't have that manual, but similar manuals say IBT Home Sensor Error. Check your accumulator belt for damage. You may also have a dirty sensor.
The belt PN is 604K20891and is rather expensive and fragile
Whit
Item, Inc.
SOURCE: how do I change the default tray on our Xerox
Log in as administrator. Press "key" button and enter pass code 1111. You will find the settings quite easily and can change them.
SOURCE: xerox workcentre 7328 fault code 062-393
This is a document scanner problem, probably a bad circuit board. (This PN may be 960K00442 but that needs to be verified in your unit)
Short of that, you could reinstall the "IIT software".
A technician could reseat the EEPROM on the IIT board which controls the document scanner. He should also reseat the scanner bar and cables underneath the glass.
Whit
Item, Inc
