See this information 8 blood pressure chart by age and height and weight
Hi Jean.
go to this link,and scroll down the page and you will see where it says,(age blood pressure chart) click into that and it will open another page.Discover your Ideal Weight - BMI Chart and Calculator.click on that and you just fill in the chart and it will tell you what you need to know.
or check this link out.
81 year old what should my blood pressure be Google Search
SOURCE: I have a Wrist Blood
Start with the unit turned off. Now hold the Power button on until it starts to blink zero (0) on the display. Wait until the display shows two zeros. Press and hold the Memory button until a two-digit number starts flashing at the bottom; this is the year setting. Press the Power button repeatedly until the year is correct. Now press the Memory button, and the month will start flashing at the top of the display. Press the Power button repeatedly until the month is correct, then press the Memory button. The day is now flashing. Set it with the Power button, then push Memory. The hour is now flashing, set it with the Power button (note that it is in 24-hour format, so 1 p.m. displays as 13). Press the Memory button to advance to the minutes, then use the Power button to set it. Finally, press the Memory button to turn the unit off. It is now ready for use.
SOURCE: what should my blood pressure be at age 54?
Blood pressure does not adjust with age...
take a look here, very informational test we use...
Blood Pressure Blood pressure chart
SOURCE: normal blood pressure for man age 80 normal weight
Age doesn't factor in, normal would be 120/70 borderline high is 140/90 > than that is high
SOURCE: blood pressure 130/90. age 67. is it too high?
blood pressure reading are an average for each individual
your doctor will have a history that he can compare your reading with to see if it is up , down or average
go talk with your doctor
