SOURCE: I cannot figure out how to put a blade in my
at the handel end it will pull apartthen slide the whats left of the old blade and put new won in its place just do it slowly so you dont forget how it goes
SOURCE: Just purchased a Stanley fatMax
Some models has 2 screws on the knife case.unscrew them and you can access to the blade.
SOURCE: I cannot open the Stanley FatMax Retractable
Try this website and scroll down to product description...
http://www.amazon.com/Stanley-10-777-Locking-Retractable-Utility/dp/B00009OYFP
SOURCE: Just purchased a Stanley FatMax 10-778 retractable
1. Make sure the side lock is unlocked.
2. Push the thumb tab all the way to the front of the blade handle.
3. Insert the blade in the opening, you may notice two notches on the top side of the blade.
4. Press the small blade release button as you slide the blade into the knife. You may have to jiggle up and down to get the two notches on the blade fully into the handle.
If properly inserted, the exposed area of the blade should look very close to an equilateral triangle.
make sure both notches of the blade are inside the handle. They notch into the thumb lever.
good luck
Testimonial: "Thanks so much!"
SOURCE: Loading instruction to change blade on Stanley
Hmmmmm.... that sounds really confusing.
Better yet... just watch this video! http://www.youtube.com/watch?v=B8Q1p-8jkyE
It's actually pretty easy! :)
It says there is one answer, but I cant see it
Just press the Battery Status button.
That does not work!
Does not work
