Well you could use another cable that you can buy from Electronic shops and it's called the i-link cable or 1394 or Firewire. You have to buy the more durable ones which are more expensive as these work better.
Windows 7 does not support USB streaming for that camera (unfortunately). You will need to purchase an i-link (or firewire) cable to transfer video from your camcorder to you computer. NOTE: Be prepared to buy a firewire adapter for your computer (unless your PC already has a firewire input). You should be able to purchase both the cable (approx. $38.00) and the adapter (approx. $10.00) from your local "big box" electronics store.
I hope this solves your issue.. :)
You require a firewire cable to connect to the PC then use Movie Maker to capture the footage.
Cameras use a 4 pin socket and computers can use 4, 6, or 9 pin sockets.
Determine which socket is on the trget computer and buy the necessary cable.
FYI: Most Laptops use 4 pin and most Desktops use 6 pin. Avoid adapters if possible.
For example; if your Desktop computer has a 6 pin socket you buy a 4 to 6 pin firewire cable. Firewire is also called iLink or IEEE 1394.
The drivers needed to connect your Sony camcorder to a computer and transfer files are already included in the operating system.
Not Supported:
The USB streaming feature is not supported with the Windows 7 operating system.
The Windows 7 Starter edition is not supported.
From the user manual page 184, they explain how to connect a iLink (IEEE 1394) cable from the camcorder to your computer. Since "USB streaming feature is not supported with Windows 7" as stated above, you now how to retrieve your video using the iLink connection instead.
Unfortunately, the camera does not come with an iLink cable, so you have to buy one. Additionally unfortunate is the fact that many computers do not have a IEEE 1394 connector to use with the iLink cable. As a result, you have to buy an adapter card for your desktop computer or hope that your laptop has a built-in IEEE 1394 port.
Once you get the iLink to IEEE 1394 issue resolved, you can then use the software provided by Sony or any DV capture software to download high quality copies of the video from your DCR-TRV250.
On page 230 of the user manual, it describes how to transfer movies from the camera to a computer using an i.Link (IEEE 1394) cable. You will need the 4 pin i.Link cable and an IEEE 1394 connector on your computer in order to do this. You cannot use the USB cable to transfer the video from this camcorder -- you can only transfer still images using the USB cable.
You will have to buy this i.Link cable and (if you don't have a IEEE 1394 port on your computer) a IEEE 1394 adapter card for you desktop computer. If your laptop computer doesn't have a IEEE 1394 adapter, then you're pretty much out of luck.
Once you have the i.Link and 1394 issues resolved, then Movie Maker should then recognize the camera.
The USB cable connection ability in Windows for video transfer was discontinued after Windows XP. Anyway, the quality of the video through the USB cable is terrible.
You'll have to buy and use a DV to Firewire cable to retrieve the video off of the camera. If you don't have a Firewire 800 adapter on your computer, you'll have to buy an adapter add-on for your desktop computer. If your laptop doesn't have a Firewire port, then you're out of luck -- buy a new laptop with one.
See pages 43 on in the user manual for more information.
You should be able to use a USB cable to connect the device to a computer, or take the memory stick from the device and use an adapter with your computer to access it like a flash drive or external hard drive. If you are using an SDHC memory card, you must buy a SDHC compatible adapter and meet the criteria for the adapter.
I have a firewire from sony 105 to macbook pro--DOES NOT WORK--adapter i used from Sony mini 7" dvd player -- thought I had it fixed :( old camera out of time....
