Question about Razor Toys
I have a 650 razor motorcycle the battery shows fully charged but clicks when I turn throttle but it does runnsometimes
  • 59 Answers
Hello
Before you change the battery check thoroughly all wires and all connections!!!!
Posted on Nov 26, 2017
SOURCE:
  • 7 Answers
SOURCE: razor e200 runs slow
you need a new battery they cost about 35$ on razor
Posted on Jun 08, 2009
SOURCE: I only get a click when I try to start the Razor quad bike
Replace the Razor Dirt Quad Control Module (201C6-3A / HB2430TYD-FS)
Posted on Jun 22, 2009
SOURCE: On an E 100 Razor scooter, the battery charger shows charged
We had the same problem that I found to have a very simple fix. It seems all that needed to be done was hold in the reset button a few seconds while the battery charger was plugged in and the light on the charger turned to red and the battery charged again. Seems like too easy of a fix but it worked for my kids scooter.
Posted on Jul 19, 2009
SOURCE: Razor MX 650 wont run
i had the same problem but fixed it this morning, i just sat far back on the seat when turning throtle with all my weight and then slid back on normal when moving, but it makes a grinding noise.
Posted on Jun 21, 2010
SOURCE: razor e300 scooter charger light stays green,
I have this same problem? What do you do? I bought a new charger thinking it was that and the light stays green on it too.
Posted on Sep 09, 2010
Why is my Razor motorcycle MX350 battery showing green but not charging
yes!your battery needs replacement.....throttle clicking after a full charge is a sign,...but that's after 2years or more,depending on how it's being used..your motor can go bad before then if you been riding in the rain--wet connectors in or out the motor can not get wet for any reason..a full dirt motor bike can not get full dirty with mud..mud catains water/water and electricity don't mix/////.motor/thottle/moisture.
Dec 17, 2012 | Razor MX500 Dirt Rocket
Motor won't engage. I turn the throttle and get a clicking sound, but nothing happens. We've charged the battery for about 4-6 hours, but the light stays red, never turns green. Help?!!
sounds like the battery is bad and not taking charge.replace battery attemp again if not then check for fuel, spark and compression.then c wat happens or wats not working any motor no matter how small or big has to hv those three things to run. hope this helps.
Jul 08, 2012 | Electric Razor Pocket Rocket Ride-on...
Razor Bella scooter problem
yes sounds like the control module, you can always jump the batteries directly to the motor to make sure that the motor is ok
Jun 25, 2012 | Razor USA Razor Pocket Mod Electric...
My son's ground force drifter is showing a charged battery but will not go. I see the full charge lights on the throttle but it when i depress the throttle, it does don't move. Anythought? Thanks
If the battery is gone(bad), sometimes it will show fully charged (volts are good).. but it has no amperage to "push" the voltage... It takes amperage to make the drifter move... (time for a new battery)... they don't last long...
Aug 03, 2011 | Razor USA Razor Ground Force Drifter Go...
I have two electric razor 175 and put new batteries in both of them. After fully charging them all i hear is a click everytime turn the throttle but nothing,, anyone that can help please help
Thank you for choosing FixYa, I will be helping you today :)
When using an electric scooter, it's always important to know that you must advance on the scooter manually, and during this action, only then can you turn the throttle. The engine on an electric scooter is not powerful enough to move a person by itself.
Hope this helps, thank you :)
Jul 03, 2011 | Razor E100 Electric Scooter
Jul 23, 2009 | Electric Razor Pocket Rocket Ride-on...
Indicator light fully charged...but barely enough power to move
i have the same exact problem on 1 of my sons MX5s..i checked all 3 batteries and all that! you left out the controller clicks when the back wheels sapose to be moving ,it's not....so worse case scenerio batt,controller,motor,(650 This time)& throttle....So theres our blue print...lets hope it's just the batteries....!
Mar 30, 2009 | Razor MX350 DIRT ROCKET - BLUE
Norelco Advantage red light meaning and source of manual
the steady red light showing when in charger shows that
it is charging. the blinking red light when taken out of
charger or turned on and off means it is not fully charged.
leave it in charger till red light turns green.
Mar 04, 2008 | Norelco Advantage 6705 X Electric Shaver
Toys Logo
143 people viewed this question
Top Razor Toys Experts
Bryan Mcphee
Bryan Mcphee
Level 1 Expert
ROB
Are you a Razor Toy Expert? Answer questions, earn points and help others
