SOURCE: apollo Horizon2 overhead projector shut off after
overheating. clean out the projector with canned air and check the fans for operation. reset the settings for factory default. if you replaced the lamp recently, reset the lamp timer through the menu.
SOURCE: apollo AI-1000 overhead projector--changing the lamp
i believe it's with the clip on the right side, but also look at the rear and bottom.
SOURCE: we just got the apollo
How long the lamp works for? Check if cooling fan is rotating. Overheating can be the cause of premature lamp failure.
