SOURCE: battery charge indicator seems faulty.
Solved own problem. Bad conection between pcb and battery contact pins. Reheat each battery pin on the pcb carefully until solder reflow occurs then remove heat. PDA now repaired
SOURCE: ryobi 18 volt batteries wont hold a charge
Ryobi batteries are specific to each Ryobi model, so please write down which model number or the original battery part number you have. How old are the batteries?
I had the same problem with many bateries I had at home, like cell-phone batteries and also some power tool bateries. Did not have any Ryobi power tools tho, so don't hold me acountable if this doesn't apply to your hardware:)
Many batteries have the "memory effect" which means that if the battery was not completely empty when it was set to recharge it might now only recharge to the level it was emptied to, so for instance if you used the power tool for 10 mins and the battery emptied to, lets say, 90% capacity, it might occure that the next time you recharge the battery it will only charge to it's 90% maximum...doing that many times lowers the maximum recharge capacity. As I heard the new Li-Ion batteries do not have this problem.
I hope this makes some sence as my english is not that good and it was a bit hard explaining my thoughts:)
SOURCE: Ryobi charging stand BCSC12C does not charge battery
i have a manul that you can fix all your batterys ,very easy email me i will send you the file cheers at [email protected]
SOURCE: light on ryobi 18v charger
More than likely a defective battery sinse the other ones charge fine..
Bring it back for exchange of another one..
Note;
We are helping people here every day on a points system.
If the information provided here was at all helpful,
please be kind and rate well.
Thank you – and enjoy your day ;o)
SOURCE: ryobi 18v lithium battery won't charge
sound to me like you have a bad battery, a lot of ryobi batterys don't last like they should i have had the same problem, but my battery was less than a year old and i took it back and they give me a new one.
