My son's Action Replay for Nintendo DS suddenly stopped working. The screen is just blank when you turn it on and it will not register when you try to hook it up via the USB to the computer. Any suggestions?
Sorry, my last desc should be ignored here are all to solutions to problems. I know:
Prob: Two white Screens:
Solution: none so far, have emails sent to Datel. see what happens. This occurs when attempting save codes with the DS and the AR is pulled out or DS powered off. My suggestion if you get a new one, only update codes using the PC software.
Prob: AR keeps asking for game cart. insertion:
Solution: remove AR and put in game cart.
Prob: AR not enough memory to update codes:
Solution: there is more bugs in their software/firmware that doesn't really know when items are deleted and space is free. You must reset AR cart. and then use the PC software to reload all the codes:
a) First I would update the AR PC software (no DS AR connected)
b) Connect DS with AR to PC then update the AR firmware
c) Disconnect DS AR from PC
d) DS off hold A+B when TURN ON DS when DS logo shows press START+SELECT with A+B still down as well, hold for a while. turn off DS
e) Reconnect to PC, turn on DS and drag the PC US codes to the DS side. (Note: I had to do 4 & 5 a couple of times it finally worked)
Prob: AR PC software not seeing the DS AR connection: Solution: The PC drivers are not being found for the NDS link. You need to do the following:
a) close the AR PC software, and disconnect the AR DS.
b) connect the AR DS and then the windows new hardware driver install window pops up. must select using the manual browse option.
c) go the the action replay directory either on the action replay CD you bought or from a extracted version from the web. (NOTE: this is not the installed location, but before where the setup.exe exists) I had lost my CD and did about 10 minutes and found a .rar of the source code.
d) pick the action replay subdirectory and click on install
e) you should see the NDS link drivers being installed.
f) start the AR PC software and attempt to connect the DS AR it should work.
-- I hope this helps anyone --
If it's the small one take off the back.if it's the big one(which i have)buy a new one or ask bust buy to fix it for you.If none of them work just buy him a new one.
When you link up your action replay to your computer press quick update and wait for the barline on the touchscreen to go to the other side and then just wait for all your games to go back onto it,(this worked with mine),
and if you type in a curtain code that code will destroy your action replay and that happened to two of my action replays! so maybe you typed that code and me i had to by another action replay!!!!!!!
First, open up Action replay DSi Code Manager. Then right-click the action replay symbol in the upper-left hand corner. Then click about Action Replay Dsi. Click Reset Hardware. WARNING: THIS WILL DELETE ALL OF YOUR CODES!!!
Wait until it is done, then add your codes back on. It should work now.
HOPE THIS HELPED!
Okay first hold the A and B buttons then turn on your ds and as soon as the second screen shows up you hold Start and select. That should fix it
Have you tried blowing on your game cartridge? somtimes the console games get dusty inside, i suppose if you try blowing in the game cartige it might work.
I can help with Solution #34/Solution #37 all u have 2 do is First I would update the AR PC software (no DS AR connected)
I know this sounds a little repetitive but what seems to always work for me when I disconnect the AR from whatever it is communicating with or its power source (by accident) is following the instruction booklet with doing a codelist reset (if you haven't figured it out it is when you push and hold a+b while turning the DS on and then pushing and holding start+select when you get to the safety screen and hold all 4 buttons for 10 seconds) If this doesn't work after you try it 20 times then you probably need a new AR (assuming you updated the PC software and AR firmware)
I have a solution to no-memory.
1) turn off the DS and press A+B
2)turn it on while still pressing A+B
3) Before it gets to "This is not endorsed or licensed by Nintendo" press start+select also while pressing A+B
4) Let go when it reaches the AR screen
That should work. It resets your DS.
Problem:
HELP!!! My DS erased all of the data programmed on it! How do I get it back?
My AR CD won't work with the computer in my house with internet connection because it was made after the year in the computer's valid reach.
The other one will work with the AR CD but it does not have internet connection because I busted it by running it so much.
WHAT DO I DO?????!!!!!!
It will not register when you try to hook it up via the USB to the computer.
The solution for the problem with no memory is press a+b then when it enters nintendo opening screen continue to hold a+b and press start+select
When i turn on my AR, there are no games anymore. i dont know why.
someone help pliz!!!!
Solution 14 fixed mine and my friends so i know that works i was pretty pissed after i found out it came up with the white screen of death
Omg some 1 help me every time i time i use the arcm the nds part wont load when its plugged in my ds but whens its not it loads for a short while then it says theres a problem and closes please help
Well the easiest way to fix the white screen is to get a flashcard and download a file to the flashcart and start you ar off of that then download the new firmware if you need a link or something watch my vid on youtube my username is wesnr just look for it on my channel (the name is How To Fix A Broken Action Replay (This Works) if you couldnt guess) hope it helps with your problem
You know nintendo didnt make them it says not licenced pr endorsed by nintendo...
Look closly at the Nopass stuff To de activate it just hold B and Select while turing on the Ds
If the a+ start+select doesnt work and its not connecting to the ARCM(action replay code manager) then u must take it to a store manager , open it and un and reconect the action replay . or u can be smart and buy a new one and stop waysting your time
for all of u who keep posting the same thing each time ur a bunch of idiots... :) bye
This happened to me too, and what I found out is if you turn the power off while the Action Replay is saving, it wipes out the data. Did something similar happen to you?
We bought our action replay for ds for a month then suddenly it stop working. We are getting white screen on the ds. Anybody got a solution for this?
My DS action replay will not load and then the screen just goes blank. Can any one help me?
(ps. I don't want to reset my action replay.)
My action replay for the ds is not working. When I turn it on, it just shows a white screen. Please help me! I looked through google for hours, for a copy of the action replay manual, because I lost mine.
I tried reconnecting it to the computer, and please don't say get a new one!Â
Everyone keeps saying that and if I buy a new one it will just happen again.
my action replay is blank!!!!!
whenever i put my action replay ds in my ds, it says that theres no game in the slot...Help?!?!?!?!?!
I put in the AR, turn on the DS. The DS screen shows up, then goes to a blank screen.
mine has done tha same bloody thing
the Action replay is screen is blank
i used an action replay on my ds with pokemon diamond now the game doesnt work
yes when u turn on the system its just blank and when u connect to laptop/pc it says waiting for ds and nothin else... any ideas ppl
everyone who posted a suggestion is a fuckwit... they said stuff like 'me to'
thats not a suggestion, nob head
I have the exact same problem. It corrupted my save file on Pokémon Pearl, but I just started a new file. Now my action replay shows up as just a blank white frozen screen. help
Posted by:Codename FotACK
If you look at wikipedia The Action Replay DS has a System called Nopass which allows you to run homebrewed programs on the DS to turn off Nopass Just hold the B and select buttons at the same time as you turn the DS on -HAL
My Action Replay DS wont work. When I turn it on the screen is blank.Â
i got the same problem too when i turn on action replay the screen is blank too so i need help.
i turn the ds on and both the screens go white.
When i turn on my action replay the screen turns white and the main menu never shows up, it just freezes up. This problem has happened to me before with all three of my old action replays.
grrr i had this too i am gonna call datel tommorow and end this once and for all!!
My brothers action replay broke when i put it im my ds. All i was getting is white screeens. What should i do? He really hates me now. He wants me to but him a new one but i dont have the money. Do you know where i can get a cheap one?
my actionreplay has a whit screen pleaz help nothing wont apera
i did not know what happened.when i use it again after a long time not using it the next time i used mine ..... I ONLY SEE A WHITE SCRREN! I THOUGHT IT WAS TAKING A LONG TIME TO LOAD! I FIGERED OUT IT DID NOT WORK!I HAVE BEEN TRYING TO KEEP CALM AND FIGHT MY PROBLEM!
the thing is happening to me!!!!!!!!!!!!!!!!!!!!!!!
I am having a similar problem with my action replay version 1.23. It was working fine until I plugged it in to my computer. After that, whenever I put it into my DS, it goes to the main screen and says "There is no DS card inserted.
i have a blank screen on my action replay
!!!!!HELP!!!!!!!!!!!!!
Yer I Have the same Problem... It's all installed updated and all that stuff.... But when I turn on my DS it's meant to go strait to the AR Menu but.... *DUH DUH DUH!* IT DOSN'T!!!
DAMN YOU CODE JUNKIES!!!
Solution:
I'm sorry to say Buy a New one or... Just stop cheating
my ar is not working. every time i go to games all the ganes are gone. if i try to upgrade it, it will say"there is not enuff room on your ar"
my action replay stopped working and I don't know what to do.
when i'm using ar on pokemon diamond the screen would just turn white
When I plug in the USB cable and have the DS and the code manager on and up, nothing happens and it doesn't recognize the ds!
i have the same problem,it erased all my data
I used my AR once, turne doff the DS. When I turned it back on, It just went to the DS screen, this is a last resort before geek squad.
my action replay wont link up to my pc!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
every time I put a game into my Nintendo DS lite, it scratches the game up more and more until eventually, my Action Replay was so scratched up, it stopped working
My DS won't start ARDS! What should I do?
I've tried to blow away dirt and dust from the cartridge and the slot.
guh this happens to me all the tiome my games wil get erased it works csometimes but mostly i get a white screen and then when it woks .1 percent of the time h games r erased so mym AR is shtit now badck to ev training for me ****
My action replay will turn on, but it's like it's been completely wiped. whenever i put in a game, it shows the code, but the game is listed as "unknown" whenever i try to add the game manually, the touch screen shows this red and blue stripe pattern going down.
my action replay is totally blank when its turned on.
I have close to the same problem but i can get to the menu. It's when i hit start it blanks out for some reason.
when i put my AR DS into the slot and turn it on and i make sure there's no dust and its all the way in, and still says theres no game or card in. any solutions?
everytime i turn on my action replay connected to the computer the left side of the action replay manager is blank and i have two white screens. what do i do i really need help?
people you're posting solutions, but you're just saying youre having those problems, too. I need to know how to fix it, no less, no more
