1999 Buick Century Logo
Posted on Jul 29, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Jumped the battery after car sat for awhile then
Jumped the battery after car sat for awhile a couple weeks. on the way home it t ran hot, when I tried to start it again, the lights went crazy and won't start. I tried it again the other day and I could open the trunk with automation key unlock and I hear a faint beep for "keys in the ignition" BUT the cat won't start at all??? My son thinks it might be sensors? Can you help?
Thanks
Adnan Bhatti
Level 3:
President:
  • Master 1,188 Answers
  • Posted on Jul 29, 2009
Adnan Bhatti
Master
Level 3:
President:
Answers
1188
Questions
Helped
410234
Points
3822
Seems that your car ran hot due to low coolant. Try refiling with coolant.
Anonymous
Level 2:
Scholar:
  • Expert 164 Answers
Anonymous
Expert
Level 2:
Scholar:
Answers
164
Questions
Helped
71275
Points
361
If you dont use the car it still use the battery so sounds like you need do slow trikle charge on the battrie. If that dosent work you might killed the battrie off. i dont this many time if not use it die fast.
Just purchased a toro zero turn mower at garage sale. Ran very well first couple weeks. I was running it the other day, shut it down, jumped back on 10 mins later, mower does not start.
You'll need to check all the safety switches. Probably one in the seat, one for the mower engaged, one for clutch/parking brake engaged, possibly one for reverse gear selected, and possibly for position of the steering arms.
I've had to replace three alternators in my 1999 toyota 4Runner between May 01, 2013 and Oct. 11, 2013. Original alternator, starter, and belts were replaced between March and May 01. In March the B+...
Have u ever went on the internet about your car.there may have been a recall on your alternator or other people with the same trouble your having.I had a mercury that I to replace the alternator three times.Come to find out there was a recall on my alternator because of how It sat in the engine.the wires running to it kept getting burned out by the powersteering belt.Just a thought when u keep replacing the same part.
Needed batery installed one now it will crank but not start acts like it is starving for fuel.It was down for 6 weeks
IF ITS CRANKING AND YOU HAVE GOOD FUEL PRESSURE I WOULD CHECK YOUR TIMING BELT TO SEE IF IT IS BROKEN OR STRIPPED OUT. HOW MANY MILES ARE ON THE CAR?
I have a 98' Grand Marquis with a 4.6 engine. as
have the alternator checked. if the alternator is not charging the vehicle is only supplied with what power is stored in the battery. once the battery is dead there is nothing to charge it
My car (2002 mercury sable v6 DOHC)is acting like it is possessed!!! Yesterday when I got in it acted like the battery was dead, but after a couple of time turning the ignition switch it turned over. I...
It may be a bad ignition switch.
Also, It could be a fuel pump, remote chance. A fuel pressure test would prove if bad. Should have 40 psi of pressure.
Any warning lights on, on the instrument panel? Check engine light? Or, they come on after the stall?
3 days ago, i went to work no problem,had to move it after 6-7 hrs of time, would not turn on 2 try's, started like normal on 3rd. 2 days ago i drove it locally a couple of times, no problems. today...
I ran into the problem and it was corrosion on the battery terminals. on the inside against the battery. also check the the terminals for good connection.
Stay warm
1helpful
Clicking starter=car not starting
the battery is located under the rear seat, check battery connections. if connections are tight replace starter.
2answers
99 dodge 1500 will not idle after jump start
i had hte same problem wiht my 95 it sat for two months and it did this either youhave a couple of dead cells in your battery or you alterator could be going bad wither that or a nasty combination of them both
Top Buick Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Buick Expert? Answer questions, earn points and help others
