Maytag bravos xl mct
SOURCE: Laptop keeps losing power at start up and shuts down repeatedly
does it run with the power cord plugged in? if so your batterys dead, otherwise harddrive/bios/motherboard fault? is your power supply charging the battery?
SOURCE: when i push power button clicks on immediately
I had this problem also and discovered an easy way to trick it into powering on: Click the power button, then within 1 second of the receiver powering off, click the power button again. The receiver should stay on this time. This works with both the button on the receiver and the remote control.
I would like to know what causes this problem and whether or not I should be concerned about damage being done. I assume this is a power protection. I haven't tried plugging this receiver into a different power socket to test, but I don't think the power plug is the problem. Note: I have the subwoofer plugged into the power plug on the back of the receiver.
SOURCE: Asko washer w6021 doesn't work. I've checked
See whether water is flowing into the wash machine. Then the door close switch.
SOURCE: maytag bravos dryer wont start
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
