SOURCE: I'm installing a Jensen vm9224bt in a 04 ford f150
I have an 05. The extra plug from the factory harness is for the steering wheel controls. Leave it unplugged. I just installed the same stereo.
The Pink wire is negatively switched wire in the green plug, this should be cut and it should function all the time it's on.
So when you put the brake on it grounds that wire and shuts the screen off (safety)
If that doesn't work it will be switched by applied 12v.
I haven't looked at what other solutions say, that's just what I see from the diagram
http://audiovox2.info/docs/common/VM9224BT/VM9224BT_IM.pdf
any problems get back to me and i'll try to help out.
