Zanussi aquasave slimline dishwasher 2000 model year
SOURCE: zanussi dishwasher DA 6141 6 years old
Check first the filters on the inlet water line (both sides). Then, if problem still exist - check that the inlet water valve works(it is an electromagnet valve, located at the pipe's entrance to the machine)). If it doesn't work, test that it get power. In case it get power and doesn't work - You can easily open the valve and clean it (from scale or other dirt). Be aware you should disconnect the power cable from machine before doing it !!!! Check as well for valve's coil resistance. In case you have no resistance measurement - you should replace it for a new one. Good luck
SOURCE: zanussi aquasave dw24
hi there sounds like your door latch switch could be at fault.
hope this helps
SOURCE: thermostat on zanussi zsf6150 dishwasher
its on the lower right hand side where the motor is there should be 2 wires going to it
SOURCE: Zanussi built in aquasave zt 685
I think I had a similar problem to this. It seems like it was starting a cycle but then it just stalled and made a buzzing noise and it did not drain properly. I opened the bottom of the dishwasher where the draining pump was located. take off the plastic cover and I found bits of broken plates were jamming the fins on the pump... Try this and see how it goes.. Hope it was of some asistance.
SOURCE: There is smelly water left in the Salt container.
I was very disappointed to find out that you did not actually offer me a solution to this (surely very simple) problem. For this reason I certainly would not take out a plan with a company like yours. You have offered me no advice whatsoever although you promised assistance.
You are obviously a company that cannot be relied on.
