(yes correct speed is selected) I could understand if pitch were low motor may need lube or a belt slipping, but this is high so motor is running too fast. And oh yes the 50/60Hz selector is in the 60Hz position. Is there some adjustment?
SOURCE: akai gx-625 reel to reel tape deck has no sound
This could be a head fault? Another possibilty is the preamp stage. You will need to look for something that would take out both channels. Such as an IC.
SOURCE: akai gx 747 dbx reel to reel need repair and service zip 95624
What problem(s) are you having with unit?
SOURCE: TEAC reel to reel tape player
Hi jvanheul
You can get a belt kit from these guys for 15 plus some post. Fresh belts, good service Bob will help you out. Cheers. A FixYa for this would make my day :)
regards
robotek
SOURCE: Gx-77 Akai reel to reel tape deck -belt
G'day Chidu
You can buy a replacement belt kit with the correct belts for your model from here
Thanks for using FixYa, a FixYa rating is a great reward for locating this part for you. Good luck with the repairs, and happy listening.
regards
robotek
SOURCE: How do I thread the tape on an Akai GX210D reel to
When facing the deck, the feed reel goes on the left and the take-up reel goes on the right. Make sure to secure each reel by engaging the reel locks on each of the spindles. Place the feed reel with the free end of the tape on the left and hanging downwards (like the letter "P"). Pass the tape to the right of the tension spindle (which is above and to the left of the play/record heads unit. Pull the tape down and pass it underneath the heads from left to right. Then on the right hand side of the heads unit pass the tape between the guide wheel and the first guide spindle to its left and just above. Then pass the tape over the top of the second guide spindle. Finally, loop the tape under the right hand tension spindle and pull it up and feed onto the take-up reel from the right in an anticlockwise direction (like the letter "g"). Once you have it through the slot in the centre of the reel, hold the tape end there with your finger and wind the reel around a few times to hold the tape in place and ... Voila!
Think I may have solved it, Finally clicked when I read that capstan motor is a synchronous motor
so I poked around on the 50/60Hz switch a bit while playing and the tape slowed down, may be bad contacts on switch still sounded a bit "tinny" though so will check value on cap it may have changed slightly as well. Will dig in a bit further later.
