SOURCE: SONY KLV30HR LCD TV RED EFFECTS
You probably need to replace the backlight. In parts less than 30$. If you know your way around these things, or know someone who does, it's not a super difficult thing to do. You can get a tutorial that's written for monitors here: http://www.inventgeek.com/Projects/shorts/lcdfix.aspx basically the same procedure for an LCD TV. Good luck!
SOURCE: Dark horizontal lines on Sony KLV-26HG2 LCD TV screen
If you can fix it by yourself, there is a problem in horizontal circuit panel, you need to check that in series because the part appear visbly good but when tested by the exact tester you register busted. that should be replaced immediately. Check also the vertical panel parts of the circuit. but if hard you do the job you may consult the service center of your TV or the vendor of the TV.
ps. please don't rate me if you are not convince of my suggestion.
best regards, melnavz
SOURCE: samsung lcd tv no picture just sound
While this is not a permanent solution, we've fond it helps... We have a Samsung LCD that does not turn on when there is too much humidity in the room. This only happens in the summer when it gets really humid. We moved our dehumidifier next to it, let it run for around 15 minutes and the TV turned on again, no problem. Lately, it's been raining alot so it's very humid. We've gotten into the habit of leaving our dehumidifier on through the night on low and we've had not issues turning on the tv since then. This is a hastle but it's either that or buying a new tv.
SOURCE: Sony KLV-S32A10 LCD TV background
You either have a malfunctioning LCD controller(T-con) or the panel itself is faulty. The T-con is very inesxpensive and easy to replace but the panel is gonna cost you nearly as much as a new tv. Let me know if you want to give the t-con a shot so that I can guide you to fix it.
