Dishwashers Logo
M
Mary Dickinson Posted on Nov 23, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Disosal leaking from bottom but also is backing water in Dishwasher when not being used.
David Ellis Rhea
Level 3:
  • Master 3,462 Answers
  • Posted on Nov 23, 2017
David Ellis Rhea
Master
Level 3:
Answers
3462
Questions
Helped
784853
Points
10903
A person familiar with plumbing needs to check your dishwasher and disposal and pipes that are connected with both of these.
To me it sounds like you have a blockage somewhere, could even be in the pipes, not the disposal or the dishwasher.
The leak of the disposal could be the disposal leaking or the plumbing pipes leaking.
God bless your efforts.
5 Related Answers
Anonymous
  • 25 Answers
  • Posted on Mar 26, 2008
SOURCE: diplomat dishwasher ADP 8332
If the pipes are cracked you may be able to get new ones from a local appliance parts dealer. If the fittings are the problem Check with the formentioned.
Anonymous
  • 413 Answers
  • Posted on Jun 08, 2008
SOURCE: Fisher & Paykel Dishwasher leaked
From what you describe, drain water from the top drawer is getting into the bottom drawer or waste water from the disposer is backing up into the bottom drawer.
1. Each drawer has its own drain hose. Each hose should terminate at the drain point with a 'Y' adapter.
2. Inspect the drain point (under the sink where the drain pipes are) to make sure this 'Y' adapter is present. (you should see two drain hoses from the DW). If not present, then the DW drain lines are not installed properly. (Someone took a shortcut and installed the 'Y' adapter behind the DW)
3. If terminated properly, make sure the drain hoses extend upward as they leave the drain point.
It is important the drain lines are connected properly to ensure proper drainage from the DW. Consult the installation manual for complete details.
Anonymous
  • 338 Answers
  • Posted on Dec 29, 2008
SOURCE: Bosch dishwasher---water filling from the bottom when off?
i would replace the inlet valve. it sounds like it is not closing all the way
Anonymous
  • Posted on Jan 15, 2009
SOURCE: water leaking from dishwasher
check the hose in the back to see if it split could be dry rotted
cesar_quant
Cesar Quant
  • 74 Answers
  • Posted on Mar 10, 2009
SOURCE: Water and soap leak out the bottom of dishwasher door?
check the drain tube that isnt damage!! or leaking!
Water leaking out of bottom of maytag dishwasher
Maybe it is leaking from the water valve that is just ouside of your dishwasher, There is a flexible line attached to the water valve that goes into the dishwasher where it is also attached. Get a flashlight and look around, if you see the valve see if the connection is leaking. If it is, see if you can tighten it. You can also shut the water to the dishwasher off here. Don't forget to turn it back on after repairs.
Frigidaire dishwasher leak
run it with no soap. if you get no leaks then cut back on your soap. you may need to run washer a few cycles to get rid of excess soap.
Asko dishwasher heavy wash light flashing and pump continually drains even with door open
The reason our Asko D3250 had this problem was because of a leak. The pump hose (approx. 2" black rubber hose - find it here http://www.repairclinic.com/PartDetail/Pump-Hose/8801409/1810263) was split, causing a leak and the blinking heavy wash light. The sensor did its job and picked up the leak.
If you're handy you don't necessarily need to call a repairman in to accomplish the work. You don't need to pull the front of the dishwasher apart. Unplug the power to the dishwasher. Take off the back bottom panel. Next, test where the leak is coming from. Place pans below the holes found on the bottom of the dishwasher. They are visible when removing the back panel and are most likely at the rear of the dishwasher. Plug the power back in then start the dishwasher. If your problem is a leak, you will easily spot it with a flashlight. After ordering and installing your part, make sure to dry all water that has settled in the bottom of the dishwasher. You can easily accomplish this through the back of the dishwasher with the panel removed. If it's still damp the sensor will continue to detect water. Once dry, start the cycle to make sure there are no more leaks before reinstalling the panel.
Leaking at the bottom of the door and unsure where plastic door seal goes.
This dishwasher will leak if there is to much water in the unit.
I have the same dishwasher with a different problem.
Mine won't circulate the water. I have not use it for a while and some water will back feed from the sink and fill the dishwasher, so if I don't check for that problem once in a while I see it start to leak.
It never has done that when the unit was working....
Dishwasher is leaking and backing up with water
Sounds like the door gasket is leaking allowing water to come out
Kenmore diswasher was runing fine till i found leak in disposal
Took plug out of new garbage disosal.Reading installation pages afer installation can be costly?Thanx
Dishwasher does not drain
If you cannot get the diswasher to drain there is some obstruction in the drain line going to the disposal. First turn the power off to the diswasher at the breaker panel then open doors under sink and follow drain line to the disposal there you will find a hose clamp(silver) that you must loosten with a flat blade screw driver ( get a bucket under the disposal) pull the drain line loose and dump out excess water and debris inspect area going into the disosal to make shure it is not clogged up
reverse your proceedure and reconnect the drain
Before trying the dishwasher take some ice cubes and run thewater then put in disposal and turn on that should clean the disposal
try your dishwasher I forgot to mention that theri is a strainer at the bottom of you dishwasher that you can remove to be sure it is not clogged up I assume that you have aready checked that
good luck
2helpful
Door leaks on the floor in front of my dishwasher
1. make sure dishwasher is level front to back and side to side.
2. check the main washer arm (WD22X154) on the bottom side for leaks. If you use heated dry, the heating elements can cause the part of the spray arm directly over it to soften and eventually leak. When water comes out that leak it can spray at the bottom of the door, splashing water inside it and resulting in your leak.
3. if 1 and 2 OK, watch how you load the lower rack. If dishes or a bowl direct water from the lower wash arm to spray against the bottom of the door, especially at the center of the door bottom, the resulting splash inside the door allows water to hit the outer door panel and drip out a one or both corners of the door.
1helpful
4answers
Dishwasher leaks
If you have nuisance water leaks around the base of your dishwasher, you may be using a detergent that is sudsing too much. Cut back on the amount of detergent you use and see if that makes a difference. Water that spills through the door vent is usually caused by improperly loading dishes. Leaks from the door itself may be caused by a faulty door gasket or door tightness adjustment. Also make sure the dishwasher is sitting level (you can adjust the front feet up or down and many units have some type of levelers at the rear). Water under the dishwasher may be originating from a leaky hose or loose hose connection. Remove the lower front panel and check the hoses. The pump seal may be defective, too; replacing this is a job for an appliance repairperson. An older dishwasher may corrode at the bottom, but this is fairly uncommon. If this is the case with your dishwasher, it's time for a new one.
Top Dishwashers Experts
Mike Cairns
Mike Cairns
