Question about Rangemaster Kitchen Ranges
Rangemaster cooker. Wok burner fails to stay lit
SOURCE:
SOURCE: burner will not stay lit
Presuming the flame is touching the thermocouple, try putting slightly more pressure on the knob and hold for a few seconds longer. If this doesn't work try going through the same process with the knob removed - if this works you need to put a small piece of packing in the shaft of the knob ( a small piece paper might do). If this fails you need a new thermocouple.
Posted on Nov 18, 2007
SOURCE: how to fit a flame failure device to rangemaster 55
the part that you need is the oven ignitor, located nest to the oven burner. that part gets hot to open the gas to the burner, that will make the oven work again.
Posted on Dec 08, 2008
  • 1214 Answers
SOURCE: Griddle burner wont spark
Make certain the burner and burner base are very clean by carefully washing in warm soapy water, using a plastic brush to scrub any residue off the surfaces. Also clean the spark ignition nub in this same way.
Posted on Jan 24, 2009
SOURCE: RANGEMASTER 110 Cooker FLAME FAILURE DEVICE fitting
My progress to date (20090127):
1 Turn off the gas supply to the oven
2 Turn off the electricity supply
3 Remove the oven linings
4 Remove the storage drawer
5 Remove the three screws holding on the bottom trim and the trim
6 Crank up the front roller
7 Pull out the oven carefully making sure the gas hose and electrical lead are long enough and not caught
8 Working from the rear of the Rangemaster, for the right-hand oven, remove the four screws on the corners of the large cover plate at the back of the oven about half way down on the left-hand side as viewed from the back.
9 Remove the cover plate.
10 Go to the front of the oven. Above the burner assembly, towards the left is a thin metal rod running front to back. This is held in place by a clip at the back and by the hole in the metal frame at the front. Remove the metal clip at the back using a pair of long-nosed pliers. Retain the clip.
11 This should release the metal rod (flame sensing device) and you should be able to push it through the hole and out at the back. It is attached to a long copper wire.
12 Go to the back of the range. You should be able to work the wire back through the hole in the rear metal plate and up to the gas valve. The wire is held in place at the gas valve by a bent clip on the rear right. Carefully bend this clip back towards the oven to release the wire.
13 The wire goes down under the gas valve and to a threded bolt end into the bottom of the gas valve ad the bolt is held in place using a locking nut.
14 Remove the locking nut using a small spanner. The threded bolt should now turn, with the aid of long-nosed pliers.
15 The next trick is to remove this threaded bolt on the end of the copper wire and I have not figured out how to do that. It will unscrew a good way but becomes tight and will not come out, as though something inside the valve is holding it in place. Could it be that the flame sensing device has to be removed and inserted from inside the gas valve? If so, what a daft piece of engineering this is.
16 HELP.
Posted on Jan 27, 2009
57 varieties
  • 1653 Answers
SOURCE: my rangemaster cooker lights on ignition but only
It will most likely be the thermostat that is faulty and will neeed replacing. If it wwas the safety device then you would not get any gas at all.
Posted on Oct 02, 2009
Rangemaster cooker.Wok burner fails to stay lit
more than likely it is a bad thermocouple.
Nov 23, 2017 | Rangemaster Kitchen Ranges
I have a rangemaster classic 90 dual fuel..we have changed the spark generator. Now it sparks on all burners but when the oven is lit the sparking continues on all burners, how do we stop this?
Hello Stephany,
this cooker has an ignition system by pressing the knob of the item that you want to ignite.
As all sparkplugs work and only the oven is the source of the problem, i think that the contact behind the knob of the oven sticks
It looks like this one and is behind the facia, between the knob and the valve.
I hope this helps, Dik
Mar 25, 2017 | Rangemaster Kitchen Ranges
Rangemaster 110 one burner will not stay lit brand new
call for a warranty service
do anything yourself will void the warranty
Oct 22, 2016 | Rangemaster Kitchen Ranges
I have a rangemaster 110 and one of the rings is playing up. It lights and then after a few seconds pops and blows itself out. Even when it is lit and running, after 10 secs or so it does it again. I have...
it is always terrible when items does not work as it should.
I expect that this cooker has flame safety.
The first thing I suspect, is your FFD (=flam failure device). Besides the burner are 2 points, one is for the spark, the other is the sensor for the safety device. On that point is connected a thin copper "wire" that goes to the tap. There it is screwed in.
The test is, stays the burner on when you keep the button pressed in. If that is the case, and the burner goes out after letting go the button, then I am sure it is the FFD.
I hope this helps, Kin regards, Dik
Feb 07, 2018 | Rangemaster 110 (Gas) Kitchen Range
My rangemaster 55 oven, stays on slow burn. and does not get any hotter... what is wrong with it ?
common problem,it will most probably be the solenoid FF device fitted by the oven burner,these can be obtained from Gas On Spares on 0121-585-7799.the will need the model number and serial number. however you are quoting two different models the Rangemaster 55 is a freestanding cooker and the 90D is a built in unit and the parts are different
Dec 26, 2010 | Rangemaster 90D Range
Burner not staying lit on rinnia rice cooker
If the rice pot is not in, burner will not light.
if that's not the case
Replace the thermal sensing unit
Nov 16, 2009 | Rinnai RER-55AS 55-Cup Rice Cooker
Warmer lights up but not getting hot - Rangemaster Toledo XT
Hi Sally
I havd exactly the same problem. I contacted Rangemaster/Aga support line (0845 603 5312 if in warranty, 0870 789 5107 if not) and they told me the heating element was shot.
My cooker is 2 1/2 years old, so out of warranty, but they were good enough to send me a new cooker top (top left hand side only of course) free of charge!!!, I just have to get it fitted.
You have to replace the whole left hand side of the cooker top too - the burner that the wok goes on!
Good luck
May 08, 2009 | Rangemaster Toledo 110 (Dual Fuel) Dual...
How to fit a flame failure device to rangemaster 55
Dec 08, 2008 | Rangemaster 110 (Dual Fuel) Dual Fuel...
Faulty plate warmer on rangemaster 110 dual fuel
We have the same problem on a Rangemaster Toledo 110. It is not a fuse.
The 'Hot' light still comes on because that is a different (parallel) circuit.
Examination by a competent electrician has found that the soldering for the wires that power the warming metal strip under the glass is faulty. You will have to ask for a replacement part.
There may be a design flaw, so you might want to enquire about the professional all gas burner top and just use the griddle as a warming plate over the second wok burner.
Good luck.
Jan 20, 2008 | Rangemaster Classic 110 (Dual Fuel) Dual...
Kitchen Ranges Logo
Top Rangemaster Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Thomas F. Schneider
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
