Hi Eric.
this link should help you out.
wiring schematics wiring diagram for 2005 chevy cobalt ignition coil pack...
if not try this one might help you find out.
SOURCE: ignition module wires to coil pack
found a good repair manual and followed the wiring diagram ~~~ Thank You / Jeff
SOURCE: cobalt no spark
I was going to say crank sensor, but you changed it. What have you done to it latley? Or did this just start? I kinda want to say PCM for some reason. Any welding done on the car latley?
SOURCE: Need wiring diagram '70 Chevy 2T trck w/electronic ignition conv
Make sure you give it a good tune up. Make sure that your rotor is moving when you crank it over. If it is moving then you will need to replace the distributor module.
SOURCE: need a diagram of the firing order of spark plug wires from coil packs to spark plugs
FROM LEFT TO RIGHT, 5/2 3/6 4/1. ASSUMING YOU HAVE THE 3.1L ENGINE.
SOURCE: rebuilt chevy 454 engine, now need distributor and
just put a new starter in my 1993 chevy 454 and now i'm not getting fire, the old starter solenoid was sticking and melted the neg battery cable. I'm wondering if that also burned something else out?
