Why does first thread break after sewing one inch on my nelco 928?
Remove all the threads.
Replace the needle.
ALWAYS RAISE the presser foot and rethread from the beginning.
Verify each thread is in the correct thread path.
ALWAYS THREAD each in the order specified or you will continue to have problems--for a lot of machines, the order is Upper Looper, Lower Looper, then needles.
Check the tension on that particular thread--too tight, it will break.
Breaking thread after about an inch usually indicates it is mis-threaded--a guide has been skipped or threaded out of order or the thread may be wrapped around something.
Serger needle thread breaking sewing discussion topic PatternReview com
http://www.amitymama.com/threads/anyone-have-an-idea-why-my-serger-needle-thread-keeps-breaking.280524
Sew What Up View thread Help Needle thread keeps breaking
SOURCE: Bobbin thread breaks
Make sure your bobbin thread is turning clockwise as it sits in the bobbin case. There is a screw on the outside of the bobbin case you can turn with your thumb slightly to adjust tension. If you dangle the case from the thread and give it a light ****, it should move down slightly when doing so-an indicator of good bobbin tension.
SOURCE: Thread breaking
Well, I have owned the Janome 1600DP with the Gracie Frame for 3 years now and have only successfully quilting 3 quilts. Its very intimidating how easily the thread breaks!!!! Add hot flashes with the frustration and I've almost given up. Today, I think I have found something. I cleaned the bobbin case, cleaned between the discs, put in a new needle (using the one recommended) but I put the spool of thread in a coffee cup located at the non-sewing end of the machine, sitting it on the Gracie Frame. Then the thread is through the metal eye ring that came with the frame. All the rest of the threading is per the Janome instructions. So far, so good. There you have it but if I had to purchase a sewing machine again for quilting quilts, it would NOT be a Janome!!!
SOURCE: I have a Kenmore 385 (12116690) the thread keeps breaking
I have this same machine, it belonged to my husbands grandmother and was given to me after she passed. I let it sit for a few years before I got it out to use it, it was just too emotional. I had this same problem, and after cleaning, it worked fine. I followed the instructions in the manual for taking out the bobbin, bobbin case and metal parts that hold it in the machine. (there are pictures in the manual to help you take it out, take it apart, and put it back in... sounds hard but it's really not). I used a tooth brush to get all of the dust bunnies out (you could go over with a vacuum hose too, after the toothbrush cleaning). After I did this it worked fine. You may want to look in the manual about oiling the machine, if it's been years since it's been done, that might help to. Hope you get it working! I love this machine, it works well and is good quality. (they don't make sewing machines like they used to, the only one I'll buy is a Kenmore!)
SOURCE: top thread keeps breaking
This sounds like a backwards needle. Take out the needle and when you re-insert it back in, make sure that put the flat side to the back.
