Smeg KSED65X-1 Kitchen Hood Logo
Posted on Jul 29, 2009
Light broken how do i put a new light bulb in my smeg cooker hood
Anonymous
Level 1:
Problem Solver:
  • Contributor 15 Answers
  • Posted on Aug 07, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
15
Questions
Helped
55980
Points
37
Lift out the filter and access the bulb from inside.
Fixed fan element, but can't remember how to put it back together again
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Jun 22, 2012 • Smeg Ovens
Light in smeg fridge freezer broken
if you replaced three bulbs and same thing happens then it is wiring or electrical.
Nov 29, 2009 • Freezers
3helpful
Bulb blew on Whirlpool cooker hood and new ones fail.
well is there a switch you might want to check that out.
Light on cooker hood doesnt work
check the switch, if you got power then the switch or bulbs sockets.
18helpful
5answers
Oven will not switch on
My Smeg oven will not work either. All I get is an "A" on the display, the clock has disappeared and as a result the oven won't come on. I see from other postings here I can bypass the clock so that the oven works again - can anyone advise how I do this?
Baumatic cooker hood lights not working
take the bulb out and bring it with you to store and see if you can find one the same . DIY stores have tons of types.Joe
1helpful
2answers
Cooker not heating up
removed broken element and replaced it. You have to access the fixing screws from the back of the cooker to remove it
4helpful
3answers
Indesit cooker hood
indesit hi 591 cooker hood bulb blew replaced it hood not working at all now
Top Smeg Kitchen Ranges Experts
vince
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Smeg Kitchen Range Expert? Answer questions, earn points and help others
