SOURCE: Homedics SS-4000 Clock Projection Display Problem
per Ken in response to SS-4500: Worked for me right away! keith
Ten8
Rank: Apprentice
Rating: 92%, 6 votes
To fix the projection display that is stuck with four 8's, hold down the hour and miute button at the same time. Keep the buttons pressed down while unplugging the power source then pluging it back it. I did this and the screen works like it did when I first got it.
Ken
SOURCE: Emerson EM2515
The phone actually has a "OPTIONS MENU" where you can set the date. When the display is showing time and date, press the "DIAL" button first and then while still holding down the "DIAL" button, press the "DEL" button the "Options Menu" will appear after about three seconds of holding down both buttons. Use the "REVIEW" arrow buttons to scroll through the menu and the "DIAL" button to select the options.
SOURCE: Low Battery Light Even with Brand New Lithium Batteries
If indeed the batteries are brand new and without a doubt charged,
then you definitely have a hardware problem in the camera.
You're probably going to have to give it in to be serviced.
Hope I helped!
Tom
SOURCE: homedics soundspa clock radio ss-4500
I had the same problem - the directions can now be found here: http://media.homedics.com/IBs/SS-4500_IB.pdf
