SOURCE: i put new batteries into both units, the indoor
Sometimes the RF frequency from the outside transmitter loses contact with the clock's frequency ( it has happened to me only twice in 6 years ), and then the outside temp will not show. Simple solution to fix this is: Take down the outside transmitter and the internally mounted clock. Remove batteries from both. Wait about 10 mts. First install batteries in the transmitter, then after about 30 seconds, install batteries in the clock. In about 5 mts, you will find the clock showing the external temp like before.
SOURCE: model 6312026 Nexxtech 433MHz wireless
Hello, you have to push few second the mode button and after date, hour etc it will be possible to change F for Celsius. He will flashing and after push one of the two button up or down.
Bye from Quebec Canada
SOURCE: blinking indicate at indoor unit
reset your unit by disconnecting the power supply for 10sec. and "on " the unit for testing. if error persist you need to replace your thermistor.
SOURCE: Outdoor transmitting
These devices have a limited range, normally 20-30' (~6-9m) and that range is influenced by the material that separates them. Any metal structures in their path can shorten the useful range. Also, I think all of these transmit only a second or two every few minutes to conserve battery power.
SOURCE: Can't reset Taylor 5367 indoor/outdoor thermom
I changed the batteries on mine and it reset itself. That was easy.
