SOURCE: kitchenaid artisan coffee machine - steam wand
good day,
hope this link below will solve your problem..
kitchen
SOURCE: I have a kitchenaid artisan
Thank you for contacting Fixya.com. Well as it has worked fine for so many days I think there is some jam in the circulation. First try running a couple cycles through of full strength vinegar. Normally you should vinegar every week then once a month if it clears. If that doesn't clear it run a weak bleach solution (6 to 1 / water to bleach) through it. Remember that after the cycles of vinegar or bleach be sure to run a rinse cycle or 2.
Please get back to us if you have any further query.
SOURCE: My solis palazzo machine will not make regular
HI
Do both buttons do the same? if they do the first thing I would do is try to reprogram the buttons.
Push and hold the button for the coffee you want, but hold it all the way through the process. Don't release the button until you get the amount of coffee you want for that button, then release the button. That should get you the same amount next time.
If this doesn't work try this.
If you make a pre-ground shot but don't put any coffee in it, and it does the same thing you have a blockage in the brew head.
If it run normally, your grind is to fine. Turn the grinder knob to a larger number. It takes 3 times to change to the new grind.
If it still dribbles, remove the brew unit (behind the door)
Holding the handle, the top left side is the brew head. There is an outlet pipe that exits the front side towards the door. 2 screws hold it to the top. Remove the 2 screws while holding the manifold. Once they are removed, lift the l assembly off (becareful, there is a spring and inside a steel ball (don't loose it or your out of luck). Turn the brew unit upside down while holding the brew head in your other hand and the steel ball should fall out. If it doesn't come out put a towel down and tap the brew unit on the towel. This should force it out.
Now remove the brew screen, by holding the screen with your finger and twisting the thumbscrew (remember thumbscrew, DON'T use the key to install the screen, use your fingers.....
Once the screen is out look at where the screen was. There are 2 holes. 1 big one in the center and a small one to the side.
Now use air to blow back through the opening where the steel ball was to clear the opening. Once its open, clean then reassemble. Brew unit on towel right side up. Drop the steel ball in first. Then the spring.
Then place the manifold on top of that with the pipe towards the door. Insert your screws (I turn them backwards a little with a little downward pressure until they feel like they drop into the threads. They should turn down easily, if not back them up a little more ( we are trying to find the old threads) and tighten. Install screen, and tighten with your fingers. The screen just needs to be flush with the bottom of the brew head.
Run another pre-ground without the coffee and rinse it out. Do this once in a while to prevent this.
Brew head cleaning Vienna/ Master
Remove the brew unit. Holding the handle, on the top left side is the brew head, there is an outlet pipe that exits the front side towards the door (looks like a long "L" pipe). 2 screws hold it to the top. Remove the 2 screws while holding the manifold ("L" pipe assembly). Once they are removed, lift the l assembly off (be careful, there is an O-ring, spring and at the end a black rubber disk or crystal ball). Do this over a towel to prevent loosing small pieces, mainly the crystal ball.
Now remove the brew screen, by holding the screen with your finger and twisting the thumbscrew (remember, thumbscrew), DON'T use the key to install the screen, use your fingers.
Once the screen is out, look at where the screen was. There are 2 holes. A big one in the center and a small one to the side.
With the brew unit upside down over the towel, insert a paperclip into the small hole and force anything out the other side. I have gotten worms almost a 1" long from this passage. The paper clip has to go from this side to prevent damage to the seat on the other side.
Clean then reassemble. Brew unit on towel right side up. Drop the crystal ball in first. Then the spring small end first on the crystal ball.
Now the O-ring over the spring, then place the manifold on top of that with the pipe towards the machine. Insert your screws (I turn them backwards a little with a little downward pressure until they feel like they drop into the threads. They should turn down easily, if not back them up a little more ( we are trying to find the old threads) and tighten. Install screen, and tighten with your fingers. The screen just needs to be flush with the bottom of the brew head. That should do it.
SOURCE: where can I find a
If you are in the states
here's one place http://www.appliancepartspros.com/part_details.aspx?part_id=3861869
But if you google it the part number is AP3861869you may find it for less.
Other parts of the world seem more difficult to track down parts but I have found somwhere in Germany and they have said that they will sell to UK residents.
http://www.kitchenaidersatzteile.com
SOURCE: Hi, I bought my kitchenaid
there is an art to working a foamer ... hence the "artisan" in the coffee-maker's name. There are several aspects to a good foam:
1. If you have been using regular milk to make your foam, try half-and-half ... the thicker consistency will give you a different result.
2. If you have been jamming the foamer head all the way to the bottom of the milk while you are foaming it, try submerging less of the foamer ... this will cause the steam to have a slightly different effect on the milk. If you have been submerging it only about half way (or not at all) try different depths. If one consistent depth is not right, try swirling it around while you foam the milk.
3. Try a different amount of steam (if your steam release valve is adjustable). Pushing a lot of pressure into the milk will give you a different result than barely turning it on.
4. Are you using a cold container or a warm one to hold the milk you are steaming? If you are still not getting the results you are looking for by playing with the other aspects of your foaming process ... try a different container (it sounds silly, but it can really help).
Before you go out and spend a bunch of money on different replacement parts for your machine, spend a while playing with these aspects of your foaming process. If none of these ideas help, then you should consider replacing pieces. Foaming milk is not as easy as it sounds ... it took me a few months of (once daily) use to really get my technique down so I could make a reliably decent foam. Don't give up! and good luck!
