Is the cleaning cycle still going? If you have a separate circuit breaker in the load center of your house for the range, you could simply turn the range off, set the circuit breaker to off, and then try to open the oven door. When you turn the breaker back on, the oven should behave normally. Do this before attempting moving the range no matter if it is electric or gas - gas lines can break when you move a range, so be prepared to turn off the gas shut off on the supply pipe near the flexible line if it should break, then get a new gas line and install it before turning the gas back on. If you are the least bit unfamiliar or don't feel confident doing this, get someone who is either a professional or someone you know that knows how to address gas appliances to move your range. If your range is electric only, then you will have no worries once you cut off the power and reset the oven to off - then turn the power back on.
SOURCE: Oven shut down during Self-cleaning
tde, sounds like your thermal fuse (TC0) opened on the back side of the oven. If this opens, it will shut the oven down. This happens alot during self cleaning on built ins. Sometimes I have to re-route the tco to a different area to prevent this from happening. Your part number is 4451442. You will have to pull the oven out far enough to remove the back paneling and replace the fuse....Catriver..post back.
SOURCE: oven door locked
First check to see if you activated the "child lock-out". See your manual to deactivate.
You could also try unplugging the unit, or trip the circuit breaker in your home which supplies power to the oven. Wait 5 minutes and turn power back on. This will reset the controls.
SOURCE: F5E1 error
Whirlpool-KitchenAid-Roper Appliances: Oven Fault Codes:
>>Exception Note:<<
Chart below does not apply to Whirlpool Models using the "Y" line in the products model numbers. Applies to models using 4 digit displays only.
F0-E0 Analog to Digital failure
Disconnect panel for 30 seconds
Should the above error re-appear, replacement of the control is required.
F1-E1 Defective ERC Replace ERC
F2-E0 Shorted Keypad Replace Keypad
F3-E0 Sensor or Sensor Fuse Open Replace Sensor or Fuse
F3-E1 Shorted wire or Sensor locate short and correct it or replace Sensor
F3-E2 Oven over heat Replace Sensor
F3-E3 Cleaning Temp over heat Replace Sensor
F5-E0 Door Error Check Door
F5-E1 Door Latch Check Latch
F5-E2 Door Switch Check Switch
SOURCE: Oven door remains locked after completion of self clean cycle
My oven door stays locked , when I press the clear button I get F1?
I hold the clear button for a few seconds and still nothing.
Please,
Thank You
SOURCE: maytag gas oven after self-clean cycle door locked "dr" on displa
unplug it and let it stand for a few minutes
let the e- prom clear
plug it back in, should unlock
if it does not you need a new sensor
