SOURCE: cannot transfer my internal memory photos into my sd memory card
if you insert the card and it would read the card immediately - not allowing you to see the pictures on the internal, that means the image storage is set to AUTO, you have to set it back to internal so you can copy them to card and just put it back to AUTO to reactivate the card
please follow this path:
insert card> turn on cam to auto> press review> "reading memory card" > press menu> scroll down to image storage> press ok to select> select INTERNAL MEMORY> press ok
scroll down to COPY> Copy pictures to memory card> scroll down to all> press ok
message to expect: "copying"
when it goes to back the menu screen
scroll to IMAGE STORAGE again and select AUTO> ok> "reading memory card"
you're supposed to see the copy of pictures from your internal and pics from your card if there's any
you can visit www.kodak.com/go/manuals
SOURCE: LG PHONE PICTURES INTO COMPUTER
you need to go to your menu bar
go over to settings and tools
go down to memory click on phone memory
down to my pictures
click options
move
mark all
and click done
and they should all move to your memory card.
hope it helps!!
((same for Videos))
SOURCE: internal memory photos download to sd card
1. Ensure memory card is inside camera.
1. Turn on camera.
2. Press Review button on back of camera
3. Then Press Menu Button on back of camera
4. Select "Image Storage" option (by depressing the joystick on RHS of back of camera).
5. Select "Internal Memory" option (by depressing the joystick on RHS).
6. Select "Continue"
7. Press Menu button.
8. Press "Review" button
9. Press "Review" button again.
10. Press "Menu" button.
11. Scroll down to "Copy" and select this option by depressing the joystick.
12. Scroll down to "All", then select by depressing the joystick.
13. Contents should now copy over from internal memory to SD card.
14. Don't forget to reselect Auto detection of SD card afterward. This is done by turning camera off then back on again. Press "Review". Press "Menu". Select "Image Storage". Select "Auto". Select "Continue".
SOURCE: transferring stored data from micro SD card on G1 to new one
plug your G1 to your PC via a USB cable that came with it .., once you plug it in you'll get a notification entitled USB connected .. select it and then choose mount ... once thats done open your My computer icon , you'll see an exrta drive that wasn't there be4 somethig like K or M .. open that and you'll see all the content of your SD card .. copy and past everything to a folder anywhere in your computer ... then all you gotta do is replace the SD card , repeat the same proccess but then time copy everything back to your new SD card .
SOURCE: Transfer "assigned media" to Micro SD
YOU CAN DO THIS BY MOVING YOUR FILES FROM YOUR MOBILE TO YOUR MEM CARD. THIS FUNCTION IS AVAILABLE IN YOUR MODEL.
IF YOU CANT DO SO. JUST TRANSFER THIS FILES TO YOUR COMPUTER VIA A DATA CABLE AND THEN TRANSFER THE SAME FILES FROM COMPUTER TO MEMCARD USING A MEMORY CARD READER.
HOPE THIS WILL HELPS U.
PLS. RATE MY SOLUTION.
NICE DAY
KETAN
