I just had my new washer professionally hooked up to washer hook ups and it will not allow the hot water function. Everything is hooked up correctly it will start filling with hot water but switches to cold. ?????????????
Hi Anita.
see if this link helps you out.
Washing Machines Hot water function won work Google Search
SOURCE: GE Washing Machine
Sounds like you have a bad fill valve on the cold water side. If your hoses are not clogged, then remove the hose and check the cold water inlet going into the machine for clogs. There is a screen that can trap mineral deposits and/or rust. If you have well water or hard water, they can become clogged easily. Sometimes you can clean them out and they will work just fine. Most of the time, however, you will need to replace the fill valve. Make sure you unplug the machine and turn the water off. The valves are electronically controlled. I hope this helps.
SOURCE: Not hot water EF0 code
Check for kinked or blocked
incoming water hoses, clean the incoming
water screens. If problem still remains,
replace the water inlet valve assembly
SOURCE: Washer Fills HOT WATER ONLY
If you checked the screens at the water inlet valve and they were not clogged, then you probably have a defective water inlet valve and will have to replace it. Hope this helped.
he F20 error is a no water detected entering machine error and yes it is related to the hot water not being hooked up.
Newer washers sense and control the incoming water temperature. If you select cold wash and cold rinse you may think that it will not ask for hot water so you don't need it hooked up but you can't do that on this washer.
Even on a cold wash the temperature sensor will read the temperature of the incoming water. If your cold water is 60 degrees then the control will sense this and it may cycle the hot water on to bring the temperature up to 70 degrees.
This temperature monitoring is something all the newer washers do. Both water valves must be hooked up to water.
