PDF
Roller Wheel Disc (older models only). 48. 15 ... change between "BIKE" and Elliptical ("ELIP"). 9. ... Replace the Brake Assembly on the Schwinn® 430/470.
PDF
Manual en Espa?ol Latino Americano: http://www.schwinnfitness.com. 430 / ... If replacement parts are necessary, use only genuine Nautilus replacement parts and ... PEDAL TO CONTINUE (if a bike) / STRIDE TO CONTINUE (if an elliptical).
The Machine Type switch (N) on the Console is preset at the factory to B (bike) or E (elliptical). If you replace the console,. it will possibly be necessary to set the ...
1_ reset the machine, disconnect the machine. 2) test the magnet, the key is magnet, test for attraction or repulsion with the magnet from your refrigerator, if do not pass the test replace the magnet. 3) replace and go and buy in homedepot for little price!
The first one, "I/O cable 8 Pin 75", Rt. Upright", runs inside the right side upright tube from the handlebar to the base of the machine. The machine will have to be partially disassembled using the original assembly instructions in reverse to access this cable.
The second cable, "I/O Cable 8 Pin 42" Upright MCB", runs from the base of the right side upright back to the Motor Control Board. If you tip the machine carefully onto it's left side with the side plastics removed you can see this cable.
check your load wires there probaly reversed. I had the same problem friday. The week before the electrican wired it. did the same cc1 then oc. had a generator company come out it was the wireing. my load and netural were reversed.
Console displays “E2” error code
Solution:
A. Check data cable integrity. All wires in cable should
be intact. If any are crimped or cut, replace cable.
B. Check data cable connections/orientation. Insure
cable is connected securely and oriented properly.
Small latch on connector should line up and snap into
place.
If the above tests reveal no problems, replace
the DC Motor.
• TECHNICAL/CUSTOMER SERVICE
Nautilus, Inc.
World Headquarters
16400 SE Nautilus Drive
Vancouver, Washington, USA
98683
Phone: 800-NAUTILUS (800-628-
8458)
Fax: 877-686-6466
• CORPORATE HEADQUARTERS
There are two bolts on the back of the treadmill. Turn the right side clockwise to make the belt go left, turn the left side clockwise to make it go right. Never tighten more than 1/2 turn at a time, and do this while machine runs at 2-3 mph. Belt should be just tight enough to not slip. If your belt is really tight and it still slips you have other problems.
