Home Logo
M
Mark Posted on Nov 18, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Have changed all washers and reseated taps in shower but shower head still leaks
NOEL
Level 3:
Top Expert:
  • Master 8,606 Answers
  • Posted on Nov 18, 2017
NOEL
Master
Level 3:
Top Expert:
Answers
8606
Questions
18
Helped
2319003
Points
68630
Hi mark.
this is all i could find on the internet,if this is no good to you go to the link at the bottom and see if it helps you out.
First, feel the water leaking from the tub spout or shower head. If it's warm, you know that the leak is coming from the hot-water valve. If the water has been dripping for a while and it is cold, the leak is probably coming from the cold-water valve. 1Start by removing the faucet handle.22 Nov 2016
How to Repair a Leaky Shower Faucet Valve - HomeTips
shower head leaks Google Search
  • Mark
    Mark Nov 18, 2017
    Thanks
  • NOEL
    NOEL Nov 18, 2017
    you are very welcome hope you get it sorted
5 Related Answers
fs8228
  • 127 Answers
  • Posted on Jun 23, 2009
SOURCE: WATER DELIVERED FROM SHOWER HEAD NOT HOT ENOUGH
I think some shower valves have a safety setting to prevent burning. maybe you could adjust that to be hotter.
Anonymous
  • 235 Answers
  • Posted on Jul 05, 2009
SOURCE: leaking shower head
Check the spout pull knob . Debris can be keeping it from closing completely.
Bill Johnson
  • 306 Answers
  • Posted on Jul 16, 2009
SOURCE: The shower hose leaks from the connection between shower hose and
have you tried teflon tape? wrap it around about 7 times and you will be fine.
Anonymous
  • 54 Answers
  • Posted on Sep 26, 2009
SOURCE: leaking faucet
Most likely bad solder joint or leak where shower arm is screwed into fitting.
Anonymous
  • 50 Answers
  • Posted on Oct 11, 2009
SOURCE: The shower head is leaking. I disassembled the
You need to pull and replace the cartridge on your shower valve most likely. It varies by Make and Model, but generally, remove the handle, remove any sleeve around the center spine, remove the round trim plate, close the service stops, remove the retaining clip or ring, and pull the cartridge straight out of the valve body by pulling on the spline... or get a cartridge puller. Then take your cartridge to the store and get a new one. Flush the valve body by slightly opening both service stops and then install the new cartridge and reverse the process.
Generally this problem occurs when sediment has torn part of the sealing o ring on the cartridge. If you send me the make/model and/or a picture I will give you the specific instructions
Leaking at the ball joint..how can i fix the shower head
undo the nut that holds the shower head on ( bit behind the ball) and inside there is either a rubber washer or a fiber washer
replace that and do it up
1helpful
The water coming out the shower jets is not powerful, help?
follow this steps and fix it. God bless you
If a faucet leaks, replace seals and gaskets .
If a shower head leaks, create a better seal or replace seals .
If a sillcock wears out, replace the washers .
If a compression faucet drips from the spout, replace the washer and/or the seat .
If a faucet leaks from the handle, replace O-ring(s), replace the packing washer, tighten the packing nut, or replace worn packing, depending on the valve type .
If a ball or cartridge faucet leaks from the collar, replace worn O-rings .
If a disk faucet leaks around the base or has reduced flow, replace cracked or pitted disk assembly or worn inlet seals .
If there is water under the sink, tighten the faucet-set locknuts under the sink. You also can replace putty or a gasket, replace a worn faucet, or replace leaky supply tubes .
If the aerator leaks around the edge, replace the washer in the aerator .
If the spray hose leaks or has reduced flow, replace the O-ring on the diverter valve, replace a worn washer at the base of the spray head, or clean the diverter valve and spray head .
Nov 25, 2013 • Home
Keeps dripping
HI, if you have changed the tap washers and they still leak, then the taps need reseating (which can be done by a plumber who has reseating tool). All the best.
Sep 04, 2012 • Home
My shower faucet is leaking
this could be abad tap washer
a faulty loose pipe connection
or a faulty tap
turn of your water supply at the outside your house before proceeding
remove the handle on your tap then remove insert screw valve usually with a spanner or shifter
you should see a copper or plastic stem inside with a flat washer at the end which
http://www.videojug.com/film/how-to-fix-a-dripping-tap-bib-or-pillar
hope this helps
My shower is leaking and i have tried a new pipe with washers what else can i do
Did you use any teflon tape on the shower arms threads to seal it up. Also check and make sure fitting on shower head isn't cracked once tighten up onto shower arm it could have a crack in it and leaks. Plastic shower heads tend to crack when they are tighten to much.
Jul 31, 2011 • Home
Customer installed a kohler tub/shower faucet and it leaks out of the head. We've changed the cartridge but the results were the samr.a Any recommrndations?
If it leaks out of the shower head and not the faucet tap, then I would look into the scald guard setting or the selector lever or even for a small scratch around the cartridge.
Kohler shower hose leak
If the problem is solely because of the rubber washer with screen you can buy any cheap replica hose and use the washer that comes with it. If the issue goes away you are done. If not, switch heads and see if the issue follows the head. If it does then there would be a crack in the head at the connection. If neither solves the issue then you must buy a new hose.
Apr 15, 2010 • Home
1helpful
2answers
Shower handle leak
turn off main water in home . turn on tap some where in home to release presser take shower handle off (screw under cap) unscrew the tap with a wrench unscrew on insides you pull out replace washer put all back togethere
2answers
Leak where Grohe shower head attached to the threaded pipe
Hello, Many shower heads have similar problems. (Very frustrating as you now know) The problem is the threads at the end of the (cheap plastic) shower neck are not flat. They are tapered (has an edge) - so it does not seat flush with the base of the shower head. Actually cuts around the rubber washer causing a leak.
What to do about it?
File the end of the neck some to create a flat surface. However, go slow. Be sure you can still screw on the shower head. Add a flat rubber washer in the shower head and plumbers tape on neck threads too.
Or Purchase a new shower neck that has a better design. The neck should unscrew from the front. Check and make sure you have an access behind the shower just in case you need to access the plumbing.
I replace the shower neck myself if there is an access.
Rob
Top Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Home Expert? Answer questions, earn points and help others
